[postgis-tickets] [PostGIS] #3644: interrupt_relate test hangs
PostGIS trac at osgeo.org
Tue Sep 27 00:20:09 PDT 2016
  Reporter:  strk     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 2.3.1
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by strk):
 PostgreSQL 9.3.9 on x86_64-unknown-linux-gnu, compiled by gcc (Ubuntu
 4.8.4-2ubuntu1~14.04.3) 4.8.4, 64-bit
 postgis_reg=# select postgis_full_version();
 NOTICE:  Function postgis_gdal_version() not found.  Is raster support
 enabled and rtpostgis.sql installed?
 DEBUG:  Function postgis_topology_scripts_installed() not found. Is
 topology support enabled and topology.sql installed?
 NOTICE:  Function postgis_raster_scripts_installed() not found. Is raster
 support enabled and rtpostgis.sql installed?
 NOTICE:  Function postgis_raster_lib_version() not found. Is raster
 -[ RECORD 1
 postgis_full_version | POSTGIS="2.4.0dev r15155" GEOS="3.6.0dev-
 CAPI-1.10.0 r4257" SFCGAL="1.2.2" PROJ="Rel. 4.9.2, 08 September 2015"
 LIBXML="2.9.3" LIBJSON="0.12"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3644#comment:1>
