[postgis-tickets] [PostGIS] #3645: Avoid loading logically deleted records from shapefiles
trac at osgeo.org
Tue Sep 27 02:56:15 PDT 2016
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS Future
Component: postgis | Version: trunk
Keywords: shapefile |
Some shapefiles contain records that are "logically deleted" according to
some convention (or standard?) used by ESRI tools and at some point some
version of QGIS too.
The convention states that a logically-deleted DBF record starts with an
asterisk on the first byte. Such records should not be loaded, unless
explicitly asked for by user.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3645>
