[postgis-tickets] [PostGIS] #3734: PostgreSQL 10 regress_selectivity fails
trac at osgeo.org
Fri Apr 7 23:57:43 PDT 2017
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Keywords: postgresql 10 |
Now that I got PostGIS at least compiling against PostgreSQL 10, back to
troubleshooting regressions. We have 2 currently, this one appears to be
a new one, but not sure when it started since our postgresql 10 tests
could not be run because it couldn't compile.
This might not be an issue -- strk how do these selectivity function thing
work?
The actuals always agree, but I looked and saw those are just constants
you have like:
select 'selectivity_02', 'actual', round(1068.0/2127.0,3);
so no big surprise there.
--- regress_selectivity_expected 2015-07-30 14:50:49.211290800
-0400
+++ /projects/postgis/tmp/2.4_pg10w64/test_64_out 2017-04-08
02:47:01.285321700 -0400
@@ -2,16 +2,16 @@
ERROR: stats for "no_stats.g" do not exist
ERROR: stats for "no_stats_join.g" do not exist
-selectivity_00|2127
-selectivity_01|1068
+selectivity_00|715
+selectivity_01|245
selectivity_02|actual|0.502
-selectivity_03|estimated|0.502
-selectivity_04|161
+selectivity_03|estimated|0.638
+selectivity_04|55
selectivity_05|actual|0.076
-selectivity_06|estimated|0.076
+selectivity_06|estimated|0.119
selectivity_07|81
selectivity_08|actual|0.038
-selectivity_09|estimated|0.038
+selectivity_09|estimated|0.231
selectivity_10|actual|0
selectivity_10|actual|1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3734>
