[postgis-tickets] [PostGIS] #3736: Investigate incorporating pgTAP tests for PostGIS
PostGIS trac at osgeo.org
Mon Apr 10 06:48:42 PDT 2017
 Reporter:  robe         |      Owner:  robe
     Type:  enhancement  |     Status:  assigned
 Priority:  medium       |  Milestone:  Management 2.0
Component:  postgis      |    Version:  trunk
 Keywords:               |
 This probably wouldn't be included in our default battery of tests as I
 think it introduces more requirements, but may be useful for things like
 upgrade bot tests.
 https://blog.2ndquadrant.com/using-postgresql-tap-framework-extensions/
 Vicky Vergara has been using this for her pgRouting tests and has been
 nudging me to try it out.  I might do that after I get at least her
 pgRouting pgTap tests running under Jenkins.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3736>
