[postgis-tickets] [PostGIS] #3511: ST_Intersects returns false positives at equator and anti/prime meridian
trac at osgeo.org
Wed Apr 12 17:19:02 PDT 2017
Reporter: jgm1972 | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.4.0
Component: postgis | Version: 2.2.x
Resolution: invalid | Keywords: ST_Intersects
Changes (by pramsey):
* status: new => closed
* resolution: => invalid
Comment:
Great circles between antipodes do not have a deterministic path. What is
the shortest paths between the north and south pole? It's any line you
wish, they are all the shortest/longest paths. As you found, adding mid-
points to lines allows you to direct the line where you "want", because
each segment in the line is now shorter than an antipodal segment and has
a deterministic path. Moral of the story: use segments of < 180 degrees.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3511#comment:4>
