[postgis-tickets] [PostGIS] #3739: ST_Within Not using index
PostGIS trac at osgeo.org
Mon Apr 17 11:34:02 PDT 2017
  Reporter:  postgispaul  |      Owner:  pramsey
      Type:  defect       |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS 2.3.3
 Component:  postgis      |    Version:  2.3.x
Resolution:               |   Keywords:
Comment (by robe):
 One more test, what happens if you change your ST_Withintest function to
 use
 && instead of ~
 and use your ST_Withintest function instead of ST_Within.
 That should determine if its ~ or _ST_Contains at fault here.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3739#comment:6>
