[postgis-tickets] [PostGIS] #3742: mvt regress failure on debbie and winnie
trac at osgeo.org
Sun Apr 23 09:34:39 PDT 2017
Reporter: robe | Owner: Björn Harrtell
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Sadly issue did not go away after the upgrade:
For the record before I did 9.3 upgrade debbie was running 9.3.10 (dronie
is running PostgreSQL 9.3.14 on x86_64-unknown-linux-gnu, compiled by gcc
(Ubuntu 4.8.4-2ubuntu1~14.04.3) 4.8.4, 64-bit and seemed to breeze thru
mvt without a problem).
Now she's running:
PostgreSQL 9.3.16 on x86_64-unknown-linux-gnu, compiled by gcc (Debian
5.2.1-22) 5.2.1 20151010, 64-bit
and still get
--- mvt_expected 2017-04-21 17:41:38.547468171 +0000
+++ /var/lib/jenkins/workspace/postgis/tmp/2_4_pg9.3w64/test_113_out
2017-04-23 16:28:57.204235634 +0000
@@ -25,8 +25,8 @@
TA6|GisKBHRlc3QSDhIEAAABARgBIgQJMt4/GgJjMRoCYzIiAigBIgIwASiAIHgC
TA7|Gk4KBHRlc3QSDBICAAAYASIECTTcPxIMEgIAARgBIgQJMt4/EgwSAgABGAEiBAk03D8aAmMxIgsK
CW90aGVydGVzdCIGCgR0ZXN0KIAgeAI=
-TA8|GkUKBHRlc3QSDBICAAAYASIECTLePxIMEgIAARgBIgQJNNw/EgwSAgACGAEiBAk03D8aAmMxIgIo
-ASICKAEiAigCKIAgeAI=
+TA8|GkEKBHRlc3QSDBICAAAYASIECTLePxIMEgIAABgBIgQJNNw/EgwSAgABGAEiBAk03D8aAmMxIgIo
+ASICKAIogCB4Ag==
TU2
ERROR: pgis_asmvt_transfn: parameter row cannot be other than a rowtype
TU3
seems like cassert isn't the issue since I would expect 9.4, 9.5, and 9.6
to fail too. This will be very very interesting.
You see anything special about the output that might give a clue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3742#comment:6>
