[postgis-tickets] [PostGIS] #3742: mvt regress failure on debbie and winnie
trac at osgeo.org
Sun Apr 23 10:58:09 PDT 2017
Reporter: robe | Owner: Björn Harrtell
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
okay I upgraded debbie's 9.4 as well which was at 9.4.5 before and was
passing.
still passes after the upgrade to
PostgreSQL 9.4.11 on x86_64-unknown-linux-gnu, compiled by gcc (Debian
5.2.1-22) 5.2.1 20151010, 64-bit
since I used the same script to compile both the new 9.3 and 9.4, I think
that rules out how I'm compiling and all that seems to also rule out
microversion.
But here's another interesting twist. I just compiled postgis on my
windows 7 64-bit against 9.6, and it fails mvt test as well same
difference.
Creating database 'postgis_reg'
Loading PostGIS into 'postgis_reg'
Loading SFCGAL into 'postgis_reg'
PostgreSQL 9.6.1, compiled by Visual C++ build 1800, 64-bit
Postgis 2.4.0dev - r15360 - 2017-04-23 17:41:51
scripts 2.4.0dev r15360
GEOS: 3.6.1-CAPI-1.10.1 r4317
PROJ: Rel. 4.9.1, 04 March 2015
SFCGAL: 1.3.0
+++ /projects/postgis/tmp/2.4_pg9.6w64/test_120_out 2017-04-23
13:45:34.273093800 -0400
@@ -25,8 +25,8 @@
TA6|GisKBHRlc3QSDhIEAAABARgBIgQJMt4/GgJjMRoCYzIiAigBIgIwASiAIHgC
TA7|Gk4KBHRlc3QSDBICAAAYASIECTTcPxIMEgIAARgBIgQJMt4/EgwSAgABGAEiBAk03D8aAmMxIgsK
CW90aGVydGVzdCIGCgR0ZXN0KIAgeAI=
-TA8|GkUKBHRlc3QSDBICAAAYASIECTLePxIMEgIAARgBIgQJNNw/EgwSAgACGAEiBAk03D8aAmMxIgIo
-ASICKAEiAigCKIAgeAI=
+TA8|GkEKBHRlc3QSDBICAAAYASIECTLePxIMEgIAABgBIgQJNNw/EgwSAgABGAEiBAk03D8aAmMxIgIo
+ASICKAIogCB4Ag==
TU2
ERROR: pgis_asmvt_transfn: parameter row cannot be other than a rowtype
TU3
winnie's 9.6 64-bit run:
Postgis 2.4.0dev - r15360 - 2017-04-23 17:53:51
SFCGAL: 1.3.0
Running tests
mvt .. ok
geobuf .. ok
So clearly PostgreSQL version (even micro) does not seem to be issue. Why
winnie's 9.6 passes and mine fails -- when we are setup mostly the same is
very puzzling.
I'm suspecting mischievous spirits haunting things :)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3742#comment:8>
