[postgis-tickets] r15367 - revise ST_Subdivide regress to use ticket instead of github pull request
Regina Obe lr at pcorp.us
Tue Apr 25 00:08:59 PDT 2017
Author: robe
Date: 2017-04-25 00:08:59 -0700 (Tue, 25 Apr 2017)
New Revision: 15367
   trunk/regress/subdivide.sql
   trunk/regress/subdivide_expected
References #3744
Modified: trunk/regress/subdivide.sql
--- trunk/regress/subdivide.sql	2017-04-25 07:02:38 UTC (rev 15366)
+++ trunk/regress/subdivide.sql	2017-04-25 07:08:59 UTC (rev 15367)
@@ -36,7 +36,7 @@
            ) as geom
-select 'https://github.com/postgis/postgis/pull/127', ST_Area(ST_Simplify(ST_Union(geom), 2))::numeric
+select '#3744', ST_Area(ST_Simplify(ST_Union(geom), 2))::numeric
 from (
          select ST_Subdivide(geom) geom
          from inverted_geom
Modified: trunk/regress/subdivide_expected
--- trunk/regress/subdivide_expected	2017-04-25 07:02:38 UTC (rev 15366)
+++ trunk/regress/subdivide_expected	2017-04-25 07:08:59 UTC (rev 15367)
@@ -2,4 +2,4 @@
 2|t|6|7
 3|t|15|9
 #3522|POINT(1 1)
-https://github.com/postgis/postgis/pull/127|1600000000000000
+#3744|1600000000000000
