[postgis-tickets] [PostGIS] #3742: mvt regress failure on debbie and winnie
PostGIS trac at osgeo.org
Tue Apr 25 00:46:25 PDT 2017
  Reporter:  robe     |      Owner:  Björn Harrtell
      Type:  defect   |     Status:  assigned
  Priority:  blocker  |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by Björn Harrtell):
 Both outputs are valid tiles and will render the same (which is why I did
 not see anything wrong at first) but the unexpected output is the most
 correct encoding.
 It must be related to the use of uthash (1) where I must be doing
 something wrong. Still can't explain at all though why it's affected by
 environment details.
 1) http://troydhanson.github.io/uthash/
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3742#comment:12>
