[postgis-tickets] [PostGIS] #3746: Bring performance tips section up to newer versions
trac at osgeo.org
Fri Apr 28 06:05:58 PDT 2017
Reporter: robe | Owner: robe
Type: task | Status: new
Priority: medium | Milestone: PostGIS 2.4.0
Component: documentation | Version: 2.3.x
Keywords: |
Clearly we haven't done much with this section in a while giving we are
still referring to 8.0. THis whole section probably needs to be updated
to the time.
Andreas Schild created an issue for the string: Current PostgreSQL
versions (including 8.0) suffer from a query optimizer weakness regarding
TOAST tables. TOAST tables are a kind of "extension room" used to store
large (in the sense of data size) values that do not fit into normal data
pages (like long texts, images or complex geometries with lots of
vertices), see <ulink url="http://www.postgresql.org/docs/current/static
/storage-toast.html">the PostgreSQL Documentation for TOAST</ulink> for
more information).
Current PostgreSQL versions (including 8.0) ?? ...current Version is 9.6
Project: PostGIS
Resource: performance_tips.xml.pot
Language: German (Germany)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3746>
