[postgis-tickets] r15376 - Make copy of string that will be deallocated and remove unused code
bjorn at wololo.org
bjorn at wololo.org
Fri Apr 28 09:16:05 PDT 2017
Author: bjornharrtell
Date: 2017-04-28 09:16:04 -0700 (Fri, 28 Apr 2017)
New Revision: 15376
trunk/postgis/geobuf.c
Modified: trunk/postgis/geobuf.c
--- trunk/postgis/geobuf.c 2017-04-28 16:10:21 UTC (rev 15375)
+++ trunk/postgis/geobuf.c 2017-04-28 16:16:04 UTC (rev 15376)
@@ -57,7 +57,9 @@
uint32_t i, k = 0;
bool geom_name_found = false;
for (i = 0; i < natts; i++) {
- char *key = tupdesc->attrs[i]->attname.data;
+ char *tkey = tupdesc->attrs[i]->attname.data;
+ char *key = palloc(sizeof(*tkey));
+ strcpy(key, tkey);
if (strcmp(key, ctx->geom_name) == 0) {
ctx->geom_index = i;
geom_name_found = true;
@@ -96,7 +98,7 @@
Data__Value *value;
- char *type, *string_value, *key;
+ char *type, *string_value;
Datum datum;
bool isnull;
@@ -104,8 +106,6 @@
continue;
k++;
- key = tupdesc->attrs[i]->attname.data;
value = palloc (sizeof (*value));
data__value__init(value);
