[postgis-tickets] [PostGIS] #3682: Strange fieldlength in result of pgsql2shp
PostGIS trac at osgeo.org
Mon May 1 01:06:20 PDT 2017
  Reporter:  postgispaul    |      Owner:  robe
      Type:  defect         |     Status:  closed
  Priority:  medium         |  Milestone:  PostGIS 2.4.0
 Component:  loader/dumper  |    Version:  2.0.x
Resolution:  fixed          |   Keywords:
Comment (by robe):
 If you look close enough you'll probably find a lot of redundant
 libraries.  So I purposely stuffed all the shp2pgsql-gui (gtk stuff in a
 subfolder) so it wouldn't screw up the PostgreSQL bin folder.  The
 versions of things are not guaranteed to be compatible between the two
 folders.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3682#comment:8>
