[postgis-tickets] [PostGIS] #3752: Mark all aggregates raster and geometry as parallel safe
trac at osgeo.org
Mon May 8 21:32:57 PDT 2017
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Keywords: |
Mark all PostGIS aggregates as safe.
As kompaz pointed out in #3751, there isn't any harm in doing this.
However since this isn't really a bug, I'm not going to backport the
change to 2.3. Just going to do for 2.4. I still think in most cases the
work can't be done in a parallel worker since the same groupings are not
guaranteed to happen in the same worker and since there is no combine
function, it can't regroup the worker groups.
That's one reason why it's not worth the bother pushing to 2.3. Since
create aggregate still requires a drop and recreate, might cause more
damage than good since some folks may not be able to cleanly upgrade 2.3
minor.
With PostgreSQL 10 there are also many more strategies supported for
parallelism, so definitely more worth while.
From release notes of 10
Support parallel btree index scans (Rahila Syed, Amit Kapila, Robert Haas,
Rafia Sabih)
Allows btree index pages to be checked by separate parallel workers.
Support parallel bitmap heap scans (Dilip Kumar)
This allows a single index scan to dispatch parallel workers to process
different areas of the heap.
Allow merge joins to be performed in parallel (Dilip Kumar)
Allow non-correlated subqueries to be run in parallel (Amit Kapila)
Improve ability of parallel workers to return pre-sorted data (Rushabh
Lathia)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3752>
