[postgis-tickets] [PostGIS] #3754: Github mirror is broken
PostGIS trac at osgeo.org
Sun May 21 20:10:03 PDT 2017
  Reporter:  robe       |      Owner:  strk
      Type:  defect     |     Status:  closed
  Priority:  blocker    |  Milestone:  Management 2.0
 Component:  buildbots  |    Version:  2.3.x
Resolution:  fixed      |   Keywords:
Comment (by robe):
 strk okay I got as far as doing a manual synch on debbie.
 I got this error:
 Warning: Permanently added 'gitlab.com,52.167.219.168' (ECDSA) to the list
 of known hosts.
 Permission denied (publickey).
 fatal: Could not read from remote repository.
 Please make sure you have the correct access rights
 and the repository exists.
 git push gitlab --tags
 Should I create a key for debbie and give you the associated public key?
 Also not sure what to do after the make daemon.  How the CGI script thing
 comes into play.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3754#comment:5>
