[postgis-tickets] [PostGIS] #3760: raster blocksize check failing on PostgreSQL 10 _raster_constraint_info_blocksize is broken
PostGIS trac at osgeo.org
Thu May 25 15:10:42 PDT 2017
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  assigned
  Priority:  blocker  |  Milestone:  PostGIS 2.4.0
 Component:  raster   |    Version:  trunk
Resolution:           |   Keywords:
Comment (by robe):
 okay figured out problem.  Has to do with change of how set returning
 functions are processed in CASE statements. Boy I didn't realized this
 change when I read about it would cause so much grief.
 So problem is our use of regexp_matches:
         CASE
                         WHEN strpos(s.consrc, 'ANY (ARRAY[') > 0 THEN
                                 split_part((regexp_matches(s.consrc,
 E'ARRAY\\[(.*?){1}\\]'))[1], ',', 1)::integer
                         ELSE
                                 regexp_replace(
                                         split_part(s.consrc, '= ', 2),
                                         '[\(\)]', '', 'g'
                                 )::integer
                         END
 I think in pre-postgresql 10 the CASE statement would short-circuit before
 it hit the regexp_matches test and since regexp_matches is as set
 returning, when it returns nothing it causes the row not to be output.
 This feels to me like an unintended consequence, but I guess I'll read the
 fine print in the release notes, and whine if it seems unintended.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3760#comment:1>
