[postgis-tickets] [PostGIS] #3761: Drop support for PostgreSQL 9.2 and erradicate all #If #def for that
    trac at osgeo.org
    Thu May 25 21:03:19 PDT 2017
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  high     |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by robe):
 In [changeset:"15402" 15402]:
 #!CommitTicketReference repository="" revision="15402"
 Get rid of all if def needed for versions of PostgreSQL lower than 9.3 and
 GEOS 3.3
 Document dropping support for PostgreSQL 9.2
 Note didn't change postgis/gserialized_estimate.c which also has an ifdef
 (leaving that for pramsey)
 References #3761 for PostGIS 2.4
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3761#comment:2>
