[postgis-tickets] [PostGIS] #3760: raster blocksize check failing on PostgreSQL 10 _raster_constraint_info_blocksize is broken
PostGIS trac at osgeo.org
Thu May 25 21:41:20 PDT 2017
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 2.4.0
 Component:  raster   |    Version:  trunk
Resolution:  fixed    |   Keywords:
Changes (by robe):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"15404" 15404]:
 #!CommitTicketReference repository="" revision="15404"
 Revise to use substring function instead of regexp_matches.
 This fixes most of the raster regress issues noted in #3759 and
 Closes #3760 for PostGIS 2.4.0 (trunk)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3760#comment:3>
