[postgis-tickets] [PostGIS] #3763: rt_union regress failure in PostgreSQL 10
trac at osgeo.org
Thu May 25 23:25:17 PDT 2017
Reporter: robe | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.4.0
Component: raster | Version: trunk
Resolution: fixed | Keywords:
Changes (by robe):
* status: assigned => closed
* resolution: => fixed
Comment:
In [changeset:"15405" 15405]:
#!CommitTicketReference repository="" revision="15405"
Revise rt_union test so passes equally on PostgreSQL 10 and lower. Lower
calls SRF for each column, triggering the same error notice multiple
times, PostgreSQL 10 called SRF only once. Revised syntax so old versions
call SRF only once.
Closes #3763 for trunk PostGIS 2.4.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3763#comment:1>
