[postgis-tickets] [PostGIS] #3766: geometry_columns and raster_columns views do not list parent partitioned tables of PostgreSQL 10
trac at osgeo.org
Sat May 27 08:51:23 PDT 2017
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Keywords: postgresql 10 |
One of the new features of PostgreSQL 10 is declaritive partitioning.
Unfortunately it seems a parent partition table is not caught by our views
though interestingly the child partitions are.
Here is an example that exercises the issue:
CREATE TABLE logs_geom_geog_parent_part (
log_id int GENERATED BY DEFAULT AS IDENTITY,
log_ts timestamp with time zone NOT NULL DEFAULT current_timestamp, geom
geometry(point), geog geography(point)
) PARTITION BY RANGE (log_ts);
CREATE TABLE pgis_parent_part_child_1 PARTITION OF pgis_parent_part FOR
VALUES FROM (unbounded) TO (unbounded);
Now if you do select from the various tables, you should have 2 records,
but get back only one.
SELECT f_table_name AS t, f_geometry_column AS gc
FROM geometry_columns;
t | gc
pgis_parent_part_child_1 | geom
(1 row)
SELECT r_table_name AS t, r_raster_column AS gc
FROM raster_columns;
t | gc
pgis_parent_part_child_1 | rast
(1 row)
-- however geography does
SELECT f_table_name AS t, f_geography_column AS gc
FROM geography_columns;
t | gc
pgis_parent_part | geog
pgis_parent_part_child_1 | geog
(2 rows)
Not sure what makes geography_columns different from raster_columns and
geometry_columns. I'm guessing it might be some sort of permission check
we are doing perhaps in raster and geometry that we aren't doing in
geography_columns.
FWIW, it's not just us. I notice in pgAdmin3 and pgADmin 4 (version 1.4),
I can't see the parent partitions listed in the table tree.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3766>
