[postgis-tickets] [PostGIS] #3914: ERROR: XX000: SQL/MM Spatial exception - geometry crosses edge 3051
trac at osgeo.org
Wed Nov 1 02:06:44 PDT 2017
Reporter: laopsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.2
Component: topology | Version: trunk
Resolution: | Keywords:
Comment (by laopsahl):
Knut a co worker of mee commented that the first line in the example above
has a spike. Postgis says the line is valid and simple .
If I remove the spike the code works ok in Postgis Topology.
select CreateTopology('test_snapto');
select TopoGeo_addLinestring('test_snapto','LINESTRING(609285.46
6549990.58,609281.0371 6549986.79,609277.63 6549983.87)',0);
select TopoGeo_addLinestring('test_snapto','LINESTRING(609281.0371
6549986.79,609292 6549984)',2);
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3914#comment:9>
