[postgis-tickets] [PostGIS] #3097: ST_Split using MULTILINESTRING blade
trac at osgeo.org
Tue Nov 7 05:08:11 PST 2017
Reporter: Mike Toews | Owner: strk
Type: enhancement | Status: reopened
Priority: medium | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Changes (by WS90):
* status: closed => reopened
* resolution: fixed =>
Comment:
Hello,
I'm working on Postgis "2.3 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"
and when I execute the following request :
SELECT ST_AsText(ST_Split(poly, blade))
FROM (
SELECT
'POLYGON((20 30, 100 180, 160 20, 20 30),(70 70, 92 105, 110 50, 70
70))'::geometry poly,
'MULTILINESTRING((150 90, 90 70, 60 20),(50 140, 90 70))'::geometry
blade
) f;
I get the error : "Splitting a Polygon by a MultiLineString is
unsupported"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3097#comment:4>
