[postgis-tickets] r16095 - Replace project-and-entend logic with
Paul Ramsey pramsey at cleverelephant.ca
Tue Nov 7 10:31:37 PST 2017
Author: pramsey
Date: 2017-11-07 10:31:37 -0800 (Tue, 07 Nov 2017)
New Revision: 16095
   branches/2.3/liblwgeom/cunit/cu_geodetic.c
   branches/2.3/liblwgeom/lwgeodetic.c
   branches/2.3/regress/geography_expected
bisect-and-recurse in geography segmentization.
Preserves "mostly equal" segment lengths, and
should be more numerically stable.
Backport to 2.3.
References #3667
Modified: branches/2.3/liblwgeom/cunit/cu_geodetic.c
--- branches/2.3/liblwgeom/cunit/cu_geodetic.c	2017-11-07 18:04:32 UTC (rev 16094)
+++ branches/2.3/liblwgeom/cunit/cu_geodetic.c	2017-11-07 18:31:37 UTC (rev 16095)
@@ -1526,8 +1526,8 @@
 	lwg1 = lwgeom_from_wkt("LINESTRING(0 20, 5 20)", LW_PARSER_CHECK_NONE);
 	lwg2 = lwgeom_segmentize_sphere(lwg1, max);
 	lwl = (LWLINE*)lwg2;
-	//wkt = lwgeom_to_ewkt(lwg2);
-	CU_ASSERT_EQUAL(lwl->points->npoints, 7);
+	// printf("%s\n", lwgeom_to_ewkt(lwg2));
+	CU_ASSERT_EQUAL(lwl->points->npoints, 9);
 	lwgeom_free(lwg1);
 	lwgeom_free(lwg2);
 	//lwfree(wkt);
Modified: branches/2.3/liblwgeom/lwgeodetic.c
--- branches/2.3/liblwgeom/lwgeodetic.c	2017-11-07 18:04:32 UTC (rev 16094)
+++ branches/2.3/liblwgeom/lwgeodetic.c	2017-11-07 18:31:37 UTC (rev 16095)
@@ -56,7 +56,7 @@
 	if ( lon < -1.0 * M_PI )
 		lon = 2.0 * M_PI + lon;
 	if ( lon == -2.0 * M_PI )
 		lon *= -1.0;
@@ -183,11 +183,11 @@
 	double zmin = FLT_MAX;
 	double zmax = -1 * FLT_MAX;
 	POINT3D pt;
 	/* Take a copy of the box corners so we can treat them as a list */
 	/* Elements are xmin, xmax, ymin, ymax, zmin, zmax */
 	memcpy(d, &(gbox->xmin), 6*sizeof(double));
 	/* Generate all 8 corner vectors of the box */
 	for ( i = 0; i < 8; i++ )
@@ -231,7 +231,7 @@
 			double angle, dotprod;
 			POINT3D pt_n;
 			pt_n.x = d[i / 2];
 			pt_n.y = d[2 + (i % 2)];
 			magnitude = sqrt(pt_n.x*pt_n.x + pt_n.y*pt_n.y);
@@ -248,7 +248,7 @@
 	/* Return the distance between the two furthest vectors */
 	return maxangle;
@@ -265,24 +265,24 @@
 	/* Zero out our return vector */
 	pt.x = pt.y = pt.z = 0.0;
 		POINT3D pt_n;
 		pt_n.x = d[i / 4];
 		pt_n.y = d[2 + ((i % 4) / 2)];
 		pt_n.z = d[4 + (i % 2)];
 		normalize(&pt_n);
 		pt.x += pt_n.x;
 		pt.y += pt_n.y;
-		pt.z += pt_n.z;
+		pt.z += pt_n.z;
 	pt.x /= 8.0;
 	pt.y /= 8.0;
 	pt.z /= 8.0;
@@ -291,7 +291,7 @@
 	cart2geog(&pt, &g);
 	out->x = longitude_degrees_normalize(rad2deg(g.lon));
 	out->y = latitude_degrees_normalize(rad2deg(g.lat));
 	return LW_SUCCESS;
@@ -475,10 +475,10 @@
 	cross_product(v1, v2, &normal);
 	normalize(&normal);
 	cross_product(&normal, v1, &v3);
 	x = dot_product(v1, v2);
 	y = dot_product(v2, &v3);
 	angle = atan2(y, x);
 	return angle;
@@ -507,7 +507,7 @@
 	double p_dot = dot_product(P1, P2);
 	POINT3D P3;
 	/* If edge is really large, calculate a narrower equivalent angle A1/A3. */
 	if ( p_dot < 0 )
@@ -525,7 +525,7 @@
 		P3 = *P2;
 	/* Normals to the A-plane and B-plane */
 	cross_product(P1, &P3, normal);
 	normalize(normal);
@@ -543,26 +543,26 @@
 	double uxuy, uyuz, uxuz;
 	double ux2, uy2, uz2;
 	double rxx, rxy, rxz, ryx, ryy, ryz, rzx, rzy, rzz;
 	/* Need a unit vector normal to rotate around */
 	unit_normal(v1, v2, &u);
 	uxuy = u.x * u.y;
 	uxuz = u.x * u.z;
 	uyuz = u.y * u.z;
 	ux2 = u.x * u.x;
 	uy2 = u.y * u.y;
 	uz2 = u.z * u.z;
 	rxx = cos_a + ux2 * (1 - cos_a);
 	rxy = uxuy * (1 - cos_a) - u.z * sin_a;
 	rxz = uxuz * (1 - cos_a) + u.y * sin_a;
 	ryx = uxuy * (1 - cos_a) + u.z * sin_a;
 	ryy = cos_a + uy2 * (1 - cos_a);
 	ryz = uyuz * (1 - cos_a) - u.x * sin_a;
 	rzx = uxuz * (1 - cos_a) - u.y * sin_a;
 	rzy = uyuz * (1 - cos_a) + u.x * sin_a;
 	rzz = cos_a + uz2 * (1 - cos_a);
@@ -672,7 +672,7 @@
 		LWDEBUG(4, "point is on plane (dot product is zero)");
 		return 0;
 	if ( w < 0 )
 		return -1;
 	else
@@ -690,7 +690,7 @@
 	robust_cross_product(b, c, &normal2);
 	normalize(&normal1);
 	normalize(&normal2);
-	return sphere_distance_cartesian(&normal1, &normal2);
+	return sphere_distance_cartesian(&normal1, &normal2);
@@ -709,18 +709,18 @@
 	double area_radians = 0.0;
 	int side;
 	GEOGRAPHIC_EDGE e;
 	angle_a = sphere_angle(b,a,c);
 	angle_b = sphere_angle(a,b,c);
 	angle_c = sphere_angle(b,c,a);
 	area_radians = angle_a + angle_b + angle_c - M_PI;
 	/* What's the direction of the B/C edge? */
 	e.start = *a;
 	e.end = *b;
 	side = edge_point_side(&e, c);
 	/* Co-linear points implies no area */
 	if ( side == 0 )
 		return 0.0;
@@ -742,7 +742,7 @@
 	int side = edge_point_side(e, p);
 	if ( side == 0 )
 		return LW_TRUE;
 	return LW_FALSE;
@@ -941,7 +941,7 @@
 	double heading = 0.0;
 	double f;
 	/* Starting from the poles? Special case. */
 	if ( FP_IS_ZERO(cos(s->lat)) )
 		return (s->lat > 0.0) ? M_PI : 0.0;
@@ -1295,7 +1295,7 @@
 		lon2 = lon1 + atan2(sin(azimuth)*sin(d)*cos(lat1), cos(d)-sin(lat1)*sin(lat2));
 	if ( isnan(lat2) || isnan(lon2) )
 		return LW_FAILURE;
@@ -1380,18 +1380,18 @@
 	/* Initialize the box with the edge end points */
 	gbox_init_point3d(A1, gbox);
 	gbox_merge_point3d(A2, gbox);
 	/* Zero length edge, just return! */
 	if ( p3d_same(A1, A2) )
 		return LW_SUCCESS;
 	/* Error out on antipodal edge */
 	if ( FP_EQUALS(A1->x, -1*A2->x) && FP_EQUALS(A1->y, -1*A2->y) && FP_EQUALS(A1->z, -1*A2->z) )
 		lwerror("Antipodal (180 degrees long) edge detected!");
 		return LW_FAILURE;
 	/* Create A3, a vector in the plane of A1/A2, orthogonal to A1  */
 	unit_normal(A1, A2, &AN);
 	unit_normal(&AN, A1, &A3);
@@ -1406,12 +1406,12 @@
 	memset(X, 0, sizeof(POINT3D) * 6);
 	X[0].x = X[2].y = X[4].z =  1.0;
 	X[1].x = X[3].y = X[5].z = -1.0;
 	/* Initialize a 2-space origin point. */
 	O.x = O.y = 0.0;
 	/* What side of the line joining R1/R2 is O? */
 	o_side = lw_segment_side(&R1, &R2, &O);
 	/* Add any extrema! */
 	for ( i = 0; i < 6; i++ )
@@ -1419,7 +1419,7 @@
 		RX.x = dot_product(&(X[i]), A1);
 		RX.y = dot_product(&(X[i]), &A3);
 		normalize2d(&RX);
 		/* Any axis end on the side of R1/R2 opposite the origin */
 		/* is an extreme point in the arc, so we add the 3-space */
 		/* version of the point on R1/R2 to the gbox */
@@ -1429,7 +1429,7 @@
 			Xn.x = RX.x * A1->x + RX.y * A3.x;
 			Xn.y = RX.x * A1->y + RX.y * A3.y;
 			Xn.z = RX.x * A1->z + RX.y * A3.z;
 			gbox_merge_point3d(&Xn, gbox);
@@ -1438,7 +1438,7 @@
 void lwpoly_pt_outside(const LWPOLY *poly, POINT2D *pt_outside)
 	/* Make sure we have boxes */
 	if ( poly->bbox )
@@ -1539,6 +1539,49 @@
+static int ptarray_segmentize_sphere_edge_recursive (
+	const POINT3D *p1, const POINT3D *p2, /* 3-space points we are interpolating beween */
+	const POINT4D *v1, const POINT4D *v2, /* real values and z/m values */
+	double d, double max_seg_length, /* current segment length and segment limit */
+	POINTARRAY *pa) /* write out results here */
+	/* Reached the terminal leaf in recursion. Add */
+	/* the left-most point to the pointarray here */
+	/* We recurse down the left side first, so outputs should */
+	/* end up added to the array in order this way */
+	if (d <= max_seg_length)
+		GEOGRAPHIC_POINT g;
+		POINT4D p;
+		cart2geog(p1, &g);
+		p.x = rad2deg(g.lon);
+		p.y = rad2deg(g.lat);
+		p.z = v1->z;
+		p.m = v1->m;
+		return ptarray_append_point(pa, &p, LW_FALSE);
+	/* Find the mid-point and recurse on the left and then the right */
+	else
+		/* Calculate mid-point */
+		POINT3D mid;
+		mid.x = (p1->x + p2->x) / 2.0;
+		mid.y = (p1->y + p2->y) / 2.0;
+		mid.z = (p1->z + p2->z) / 2.0;
+		normalize(&mid);
+		/* Calculate z/m mid-values */
+		/* (ignore x/y, we get those from the 3-space calculations) */
+		POINT4D midv;
+		midv.z = (v1->z + v2->z) / 2.0;
+		midv.m = (v1->m + v2->m) / 2.0;
+		/* Recurse on the left first */
+		ptarray_segmentize_sphere_edge_recursive(p1, &mid, v1, &midv, d/2.0, max_seg_length, pa);
+		ptarray_segmentize_sphere_edge_recursive(&mid, p2, &midv, v2, d/2.0, max_seg_length, pa);
+		return LW_SUCCESS;
 * Create a new point array with no segment longer than the input segment length (expressed in radians!)
 * @param pa_in - input point array pointer
@@ -1550,93 +1593,51 @@
 	POINTARRAY *pa_out;
 	int hasz = ptarray_has_z(pa_in);
 	int hasm = ptarray_has_m(pa_in);
-	int pa_in_offset = 0; /* input point offset */
-	POINT4D p1, p2, p;
-	GEOGRAPHIC_POINT g1, g2, g;
-	double d;
+	POINT4D p1, p2;
+	POINT3D q1, q2;
+	GEOGRAPHIC_POINT g1, g2;
+	int i;
 	/* Just crap out on crazy input */
 	if ( ! pa_in )
-		lwerror("ptarray_segmentize_sphere: null input pointarray");
-	if ( max_seg_length <= 0.0 )
-		lwerror("ptarray_segmentize_sphere: maximum segment length must be positive");
+		lwerror("%s: null input pointarray", __func__);
+	if ( max_seg_length <= 0.0 )
+		lwerror("%s: maximum segment length must be positive", __func__);
 	/* Empty starting array */
 	pa_out = ptarray_construct_empty(hasz, hasm, pa_in->npoints);
-	/* Add first point */
-	getPoint4d_p(pa_in, pa_in_offset, &p1);
-	ptarray_append_point(pa_out, &p1, LW_FALSE);
-	geographic_point_init(p1.x, p1.y, &g1);
-	pa_in_offset++;
-	while ( pa_in_offset < pa_in->npoints )
+	/* Simple loop per edge */
+	for (i = 1; i < pa_in->npoints; i++)
-		getPoint4d_p(pa_in, pa_in_offset, &p2);
+		getPoint4d_p(pa_in, i-1, &p1);
+		getPoint4d_p(pa_in, i, &p2);
+		geographic_point_init(p1.x, p1.y, &g1);
 		geographic_point_init(p2.x, p2.y, &g2);
 		/* Skip duplicate points (except in case of 2-point lines!) */
-		if ( (pa_in->npoints > 2) && p4d_same(&p1, &p2) )
-			/* Move one offset forward */
-			p1 = p2;
-			g1 = g2;
-			pa_in_offset++;
+		if ((pa_in->npoints > 2) && p4d_same(&p1, &p2))
 			continue;
 		/* How long is this edge? */
-		d = sphere_distance(&g1, &g2);
-		/* We need to segmentize this edge */
-		if ( d > max_seg_length )
+		double d = sphere_distance(&g1, &g2);
+		if (d > max_seg_length)
-			int nsegs = 1 + d / max_seg_length;
-			int i;
-			double dzz = 0, dmm = 0;
-			double delta = d / nsegs;
-			/* The independent Z/M values on the ptarray */
-			if ( hasz ) dzz = (p2.z - p1.z) / nsegs;
-			if ( hasm ) dmm = (p2.m - p1.m) / nsegs;
-			g = g1;
-			p = p1;
-			for ( i = 0; i < nsegs - 1; i++ )
-				GEOGRAPHIC_POINT gn;
-				double heading;
-				/* Compute the current heading to the destination */
-				heading = sphere_direction(&g, &g2, (nsegs-i) * delta);
-				/* Move one increment forwards */
-				sphere_project(&g, delta, heading, &gn);
-				g = gn;
-				p.x = rad2deg(g.lon);
-				p.y = rad2deg(g.lat);
-				if ( hasz )
-					p.z += dzz;
-				if ( hasm )
-					p.m += dmm;
-				ptarray_append_point(pa_out, &p, LW_FALSE);
-			ptarray_append_point(pa_out, &p2, LW_FALSE);
+			geog2cart(&g1, &q1);
+			geog2cart(&g2, &q2);
+			/* 3-d end points, XYZM end point, current edge size, min edge size */
+			ptarray_segmentize_sphere_edge_recursive(&q1, &q2, &p1, &p2, d, max_seg_length, pa_out);
-		/* This edge is already short enough */
+		/* If we don't segmentize, we need to add first point manually */
 		else
-			ptarray_append_point(pa_out, &p2, (pa_in->npoints==2)?LW_TRUE:LW_FALSE);
+			ptarray_append_point(pa_out, &p1, LW_TRUE);
-		p1 = p2;
-		g1 = g2;
-		pa_in_offset++;
-	return pa_out;
+	/* Always add the last point */
+	ptarray_append_point(pa_out, &p2, LW_TRUE);
+	return pa_out;
@@ -1653,15 +1654,15 @@
 	LWPOLY *lwpoly_in, *lwpoly_out;
 	LWCOLLECTION *lwcol_in, *lwcol_out;
 	int i;
 	/* Reflect NULL */
 	if ( ! lwg_in )
 		return NULL;
 	/* Clone empty */
 	if ( lwgeom_is_empty(lwg_in) )
 		return lwgeom_clone(lwg_in);
 	switch (lwg_in->type)
 	case MULTIPOINTTYPE:
@@ -1699,7 +1700,7 @@
 		        lwg_in->type, lwtype_name(lwg_in->type));
 		break;
 	lwerror("lwgeom_segmentize_sphere got to the end of the function, should not happen");
 	return NULL;
@@ -1716,16 +1717,16 @@
 	const POINT2D *p;
 	GEOGRAPHIC_POINT a, b, c;
 	double area = 0.0;
 	/* Return zero on nonsensical inputs */
 	if ( ! pa || pa->npoints < 4 )
 		return 0.0;
 	p = getPoint2d_cp(pa, 0);
 	geographic_point_init(p->x, p->y, &a);
 	p = getPoint2d_cp(pa, 1);
 	geographic_point_init(p->x, p->y, &b);
 	for ( i = 2; i < pa->npoints-1; i++ )
 		p = getPoint2d_cp(pa, i);
@@ -1733,7 +1734,7 @@
 		area += sphere_signed_area(&a, &b, &c);
 		b = c;
 	return fabs(area);
@@ -2023,12 +2024,12 @@
 		lwerror("Distance must be between 0 and %g", M_PI * spheroid->radius);
 		return NULL;
 	/* Convert to ta geodetic point */
 	x = lwpoint_get_x(r);
 	y = lwpoint_get_y(r);
 	geographic_point_init(x, y, &geo_source);
 	/* Try the projection */
 	if( spheroid_project(&geo_source, spheroid, distance, azimuth, &geo_dest) == LW_FAILURE )
@@ -2036,7 +2037,7 @@
 		lwerror("Unable to project from (%g %g) with azimuth %g and distance %g", x, y, azimuth, distance);
 		return NULL;
 	/* Build the output LWPOINT */
 	pa = ptarray_construct(0, 0, 1);
 	pt_dest.x = rad2deg(longitude_radians_normalize(geo_dest.lon));
@@ -2071,13 +2072,13 @@
 	x2 = lwpoint_get_x(s);
 	y2 = lwpoint_get_y(s);
 	geographic_point_init(x2, y2, &g2);
 	/* Same point, return NaN */
 	if ( FP_EQUALS(x1, x2) && FP_EQUALS(y1, y2) )
 		return NAN;
 	/* Do the direction calculation */
 	return spheroid_direction(&g1, &g2, spheroid);
@@ -2096,10 +2097,10 @@
 	gbox_init(&gbox1);
 	gbox_init(&gbox2);
 	assert(lwgeom1);
 	assert(lwgeom2);
 	LWDEBUGF(4, "entered function, tolerance %.8g", tolerance);
 	/* What's the distance to an empty geometry? We don't know.
@@ -2174,7 +2175,7 @@
 			return 0.0;
 		/* Not inside, so what's the actual distance? */
 		for ( i = 0; i < lwpoly->nrings; i++ )
@@ -2315,7 +2316,7 @@
 	int type1, type2;
 	GBOX gbox1, gbox2;
 	gbox1.flags = gbox2.flags = 0;
 	assert(lwgeom1);
 	assert(lwgeom2);
@@ -2511,13 +2512,13 @@
 	ll2cart(p, &A1);
 	for ( i = 1; i < pa->npoints; i++ )
 		ll2cart(p, &A2);
 		edge_calculate_gbox(&A1, &A2, &edge_gbox);
 		/* Initialize the box */
@@ -2531,7 +2532,7 @@
 			gbox_merge(&edge_gbox, gbox);
 		A1 = A2;
@@ -2729,7 +2730,7 @@
 	if ( lwgeom_is_empty(geom) )
 		return LW_TRUE;
 	switch (geom->type)
 	case POINTTYPE:
@@ -2880,7 +2881,7 @@
 		/* Add in the vertical displacement if we're in 3D */
 		if ( hasz )
 			seglength = sqrt( (zb-za)*(zb-za) + seglength*seglength );
 		/* Add this segment length to the total */
 		length += seglength;
@@ -3057,11 +3058,11 @@
 	POINT3D AC; /* Center point of A1/A2 */
 	double min_similarity, similarity;
 	/* The normalized sum bisects the angle between start and end. */
 	vector_sum(A1, A2, &AC);
 	normalize(&AC);
 	/* The projection of start onto the center defines the minimum similarity */
 	min_similarity = dot_product(A1, &AC);
@@ -3097,7 +3098,7 @@
 	if ( FP_IS_ZERO(dp) )
 		return 0;
 	return dp < 0.0 ? -1 : 1;
@@ -3112,11 +3113,11 @@
 	double ab_dot;
 	int a1_side, a2_side, b1_side, b2_side;
 	int rv = PIR_NO_INTERACT;
 	unit_normal(B1, B2, &BN);
 	/* Are A-plane and B-plane basically the same? */
 	ab_dot = dot_product(&AN, &BN);
 	if ( FP_EQUALS(fabs(ab_dot), 1.0) )
@@ -3130,7 +3131,7 @@
 		return rv;
 	/* What side of plane-A and plane-B do the end points */
 	/* of A and B fall? */
 	a1_side = dot_product_side(&BN, A1);
@@ -3169,7 +3170,7 @@
 			return PIR_INTERSECTS;
 		return PIR_NO_INTERACT;
@@ -3199,7 +3200,7 @@
 		/* Touches at B2, B1 is on what side? */
 		rv |= (b1_side < 0 ? PIR_B_TOUCH_RIGHT : PIR_B_TOUCH_LEFT);
 	return rv;
@@ -3245,16 +3246,16 @@
 			continue;
 		/* Our test point is on an edge end! Point is "in ring" by our definition */
 		if ( point3d_equals(&S1, &E1) )
 			return LW_TRUE;
 		/* Calculate relationship between stab line and edge */
 		inter = edge_intersects(&S1, &S2, &E1, &E2);
 		/* We have some kind of interaction... */
 		if ( inter & PIR_INTERSECTS )
@@ -3264,7 +3265,7 @@
 				return LW_TRUE;
 			/* It's a touching interaction, disregard all the left-side ones. */
 			/* It's a co-linear intersection, ignore those. */
 			if ( inter & PIR_B_TOUCH_RIGHT || inter & PIR_COLINEAR )
@@ -3283,7 +3284,7 @@
 			LWDEBUGF(4,"    edge (%d) did not cross", i);
 		/* Increment to next edge */
 		E1 = E2;
Modified: branches/2.3/regress/geography_expected
--- branches/2.3/regress/geography_expected	2017-11-07 18:04:32 UTC (rev 16094)
+++ branches/2.3/regress/geography_expected	2017-11-07 18:31:37 UTC (rev 16095)
@@ -27,6 +27,6 @@
 #2422|1|1609|t|t|1400.230|1396.816|1400.230|1400.230
 #2422|1|1600|t|t|1400.230|1396.816|1400.230|1400.230
 #2422|1|1068|f|f|1400.230|1396.816|1400.230|1400.230
-segmentize_geography|49789
+segmentize_geography|39092
 segmentize_geography2|t
 segmentize_geography_3667|t
