[postgis-tickets] [PostGIS] #3921: ALTER EXTENSION upgrade failing at ST_CurveToLine
PostGIS trac at osgeo.org
Wed Nov 8 05:03:37 PST 2017
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 2.5.0
 Component:  buildbots  |    Version:  trunk
Resolution:             |   Keywords:
Comment (by robe):
 It actually does use make install, but winnie has to test against another
 PostgreSQL instance (the VC++ build) so the install location is no good
 since it's the MingW PostgreSQL install location and since install
 location can't be controlled with --prefix, it's not really useful.
 Also the installed items along with some other binaries (e.g. GDAL etc)
 need to be packaged in a zip file for windows users to consume.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3921#comment:8>
