[postgis-tickets] [PostGIS] #3924: ST_Project does not project perfectly east-west
trac at osgeo.org
Wed Nov 8 07:03:09 PST 2017
Reporter: petermj | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.4.2
Component: postgis | Version: 2.4.x
Resolution: invalid | Keywords:
Comment (by pramsey):
Use ST_Translate in geometry space. `ST_Project(g,a,b)` is only defined
for geography, so if you feed it a geometry, the system will quietly cast
to geography and then run it for you in geography space.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3924#comment:3>
