[postgis-tickets] r16106 - Remove un-used static function
Paul Ramsey pramsey at cleverelephant.ca
Thu Nov 9 09:34:14 PST 2017
Author: pramsey
Date: 2017-11-09 09:34:14 -0800 (Thu, 09 Nov 2017)
New Revision: 16106
   trunk/postgis/mvt.c
Modified: trunk/postgis/mvt.c
--- trunk/postgis/mvt.c	2017-11-09 17:21:45 UTC (rev 16105)
+++ trunk/postgis/mvt.c	2017-11-09 17:34:14 UTC (rev 16106)
@@ -639,19 +639,6 @@
 	POSTGIS_DEBUGF(3, "parse_values n_tags %zd", ctx->feature->n_tags);
-static int max_type(LWCOLLECTION *lwcoll)
-	int i, max = POINTTYPE;
-	for (i = 0; i < lwcoll->ngeoms; i++) {
-		uint8_t type = lwcoll->geoms[i]->type;
-		if (type == POLYGONTYPE || type == MULTIPOLYGONTYPE)
-			return POLYGONTYPE;
-		else if (type == LINETYPE || type == MULTILINETYPE)
-			max = LINETYPE;
-	return max;
  * In place process a collection to find a concrete geometry
  * object and expose that as the actual object. Will some
