[postgis-tickets] [PostGIS] #3675: Relationship functions not using an index in some cases
trac at osgeo.org
Thu Nov 9 09:42:59 PST 2017
Reporter: robe | Owner: robe
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.3.2
Component: postgis | Version: 2.3.x
Resolution: fixed | Keywords:
Comment (by pramsey):
Our demo SQL has gotten a little spread out. Here's a complete set of SQL
that demonstrates the condition:
-- Create data table and index. Analyze.
DROP TABLE IF EXISTS e;
CREATE TABLE e AS
SELECT row_number() OVER() As gid,
ST_SetSRID( ST_Point(x,y) ,4326) As geom,
x as longitude, y as latitude
FROM generate_series(-90,90) As y, generate_series(-179,179) As x;
CREATE INDEX idx_e_geom_gist ON e USING gist(geom);
ANALYZE e;
-- Start with a high cost ST_SetSRID
ALTER FUNCTION ST_SetSRID(geometry, integer) COST 1;
-- [A] Query plan hits
EXPLAIN SELECT gid
FROM e
WHERE ST_DWithin(e.geom ,
ST_SetSRID(ST_Point( 151.27544336, -33.87718472), 4326), 1);
-- [B] Query plan hits index
EXPLAIN SELECT gid
FROM e, (SELECT longitude, latitude FROM e WHERE longitude = -1 and
latitude = -1) As c
ST_SetSRID(ST_Point( c.longitude, c.latitude), 4326), 1);
-- Set ST_SetSRID cost to a high value
ALTER FUNCTION ST_SetSRID(geometry, integer) COST 100;
-- [B] Query plan now misses index!!
EXPLAIN SELECT gid
latitude = -1) As c
-- Can we fix it by changing the ST_DWithin function into
-- undecorated (no strict, no immutable) version?
CREATE OR REPLACE FUNCTION ST_DWithin(geom1 geometry, geom2 geometry,
float8)
RETURNS boolean
AS 'SELECT $1 OPERATOR(&&) ST_Expand($2,$3) AND $2 OPERATOR(&&)
ST_Expand($1,$3) AND _ST_DWithin($1, $2, $3)'
LANGUAGE 'sql';
-- [B] Query plan still misses index!!
EXPLAIN SELECT gid
latitude = -1) As c
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3675#comment:17>
