[postgis-tickets] r16109 - Prepare for release
Paul Ramsey pramsey at cleverelephant.ca
Wed Nov 15 09:54:40 PST 2017
Author: pramsey
Date: 2017-11-15 09:54:39 -0800 (Wed, 15 Nov 2017)
New Revision: 16109
   branches/2.3/ChangeLog
   branches/2.3/NEWS
   branches/2.3/README.postgis
   branches/2.3/Version.config
   branches/2.3/doc/release_notes.xml
Prepare for release
Modified: branches/2.3/ChangeLog
--- branches/2.3/ChangeLog	2017-11-14 05:42:21 UTC (rev 16108)
+++ branches/2.3/ChangeLog	2017-11-15 17:54:39 UTC (rev 16109)
@@ -1,3 +1,56 @@
+2017-11-09 09:01  Regina Obe <lr at pcorp.us>
+	* [r16101] NEWS, extensions/upgradeable_versions.mk: Add missing
+	  2.2.6 upgrade path
+	  References #3926 for PostGIS 2.3.5
+2017-11-09 08:55  Regina Obe <lr at pcorp.us>
+	* [r16100] NEWS: Add missing release notes for ST_Segmentize
+	  geography fix.
+	  References #3667 for PostGIS 2.3.5
+2017-11-07 18:31  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r16095] liblwgeom/cunit/cu_geodetic.c, liblwgeom/lwgeodetic.c,
+	  regress/geography_expected: Replace project-and-entend logic with
+	  bisect-and-recurse in geography segmentization.
+	  Preserves "mostly equal" segment lengths, and
+	  should be more numerically stable.
+	  Backport to 2.3.
+	  References #3667
+2017-10-31 15:33  Sandro Santilli <strk at kbt.io>
+	* [r16087] configure.ac, liblwgeom/Makefile.in: Make sure target
+	  directories are created before copying files to them
+	  References #3912 for 2.3 branch
+	  References #3916 for 2.3 branch
+2017-10-21 09:04  Sandro Santilli <strk at kbt.io>
+	* [r16030] .gitignore, GNUmakefile.in, configure.ac,
+	  liblwgeom/Makefile.in, loader/Makefile.in, raster/install-sh,
+	  raster/loader/Makefile.in, utils/Makefile.in: Put build AUX files
+	  under build-aux
+	  Cleans and ignore build aux files from new location,
+	  and remove spurious install-sh from repository.
+2017-10-18 18:19  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r16010] HOWTO_RELEASE, NEWS, Version.config,
+	  extensions/upgradeable_versions.mk: Push versions to dev
+2017-10-18 18:09  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r16008] ChangeLog, HOWTO_RELEASE, NEWS, README.postgis,
+	  Version.config, doc/release_notes.xml,
+	  extensions/upgradeable_versions.mk: Prepare for 2.3.4 release
 2017-10-17 16:54  Paul Ramsey <pramsey at cleverelephant.ca>
 	* [r15998] NEWS, liblwgeom/cunit/cu_geodetic.c, liblwgeom/g_box.c:
Modified: branches/2.3/NEWS
--- branches/2.3/NEWS	2017-11-14 05:42:21 UTC (rev 16108)
+++ branches/2.3/NEWS	2017-11-15 17:54:39 UTC (rev 16109)
@@ -1,5 +1,5 @@
 PostGIS 2.3.5
-2017/xx/xx
+2017/11/15
   * Bug Fixes and Enhancements
Modified: branches/2.3/README.postgis
--- branches/2.3/README.postgis	2017-11-14 05:42:21 UTC (rev 16108)
+++ branches/2.3/README.postgis	2017-11-15 17:54:39 UTC (rev 16109)
@@ -1,8 +1,8 @@
 PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 2.3.4
-:Date: 2017-10-18
+:Version: 2.3.5
+:Date: 2017-11-15
 :Website: http://postgis.net
 This distribution contains a module which implements GIS simple features, ties
Modified: branches/2.3/Version.config
--- branches/2.3/Version.config	2017-11-14 05:42:21 UTC (rev 16108)
+++ branches/2.3/Version.config	2017-11-15 17:54:39 UTC (rev 16109)
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=2
 POSTGIS_MINOR_VERSION=3
-POSTGIS_MICRO_VERSION=5dev
+POSTGIS_MICRO_VERSION=5
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
Modified: branches/2.3/doc/release_notes.xml
--- branches/2.3/doc/release_notes.xml	2017-11-14 05:42:21 UTC (rev 16108)
+++ branches/2.3/doc/release_notes.xml	2017-11-15 17:54:39 UTC (rev 16109)
@@ -2,7 +2,19 @@
 <appendix id="release_notes">
   <title>Appendix</title>
     <subtitle>Release Notes</subtitle>
     <sect1>
+      <title>Release 2.3.5</title>
+      <para>Release date: 2017/11/15</para>
+      <para>This is a bug fix and performance improvement release.</para>
+      <simplesect>
+        <title>Bug Fixes and Enhancements</title>
+        <para>#3667, Fix for bug in geography ST_Segmentize</para>
+        <para>#3926, Add missing 2.2.6 upgrade path</para>
+      </simplesect>
+    </sect1>
+    <sect1>
       <title>Release 2.3.4</title>
       <para>Release date: 2017/10/18</para>
