[postgis-tickets] r16112 - Prepare for 2.4.2
Paul Ramsey
pramsey at cleverelephant.ca
Wed Nov 15 10:11:14 PST 2017
Author: pramsey
Date: 2017-11-15 10:11:13 -0800 (Wed, 15 Nov 2017)
New Revision: 16112
branches/2.4/
branches/2.4/ChangeLog
branches/2.4/NEWS
branches/2.4/README.postgis
branches/2.4/Version.config
branches/2.4/extensions/upgradeable_versions.mk
Prepare for 2.4.2
Property changes on: branches/2.4
___________________________________________________________________
Modified: svn:ignore
- aclocal.m4
autom4te.cache
configure
config.h
config.guess
config.log
config.status
config.sub
GNUmakefile
install-sh
libtool
ltmain.sh
Makefile.config
postgis_config.h
postgis_svn_revision.h
svnrevision.h
+ aclocal.m4
autom4te.cache
build-aux
configure
config.h
config.guess
config.log
config.status
config.sub
GNUmakefile
install-sh
libtool
ltmain.sh
Makefile.config
postgis_config.h
svnrevision.h
Modified: branches/2.4/ChangeLog
--- branches/2.4/ChangeLog 2017-11-15 18:04:29 UTC (rev 16111)
+++ branches/2.4/ChangeLog 2017-11-15 18:11:13 UTC (rev 16112)
@@ -1,3 +1,93 @@
+2017-11-14 05:42 Regina Obe <lr at pcorp.us>
+ * [r16108] doc/extras_tigergeocoder.xml: note about enhanced
+ feature in reverse_geocode when zcta5 data is loaded.
+2017-11-09 09:06 Regina Obe <lr at pcorp.us>
+ * [r16102] NEWS, extensions/upgradeable_versions.mk: Add missing
+ 2.3.4 upgrade path (as provided by Muhammad Usama)
+ Also remove 2.3 and 2.4 dev releases and add missing 2.2.6
+ Closes #3926 for PostGIS 2.4.2
+2017-11-09 08:53 Regina Obe <lr at pcorp.us>
+ * [r16099] NEWS: fix spacing
+2017-11-09 08:52 Regina Obe <lr at pcorp.us>
+ * [r16098] NEWS: Add missing release notes for ST_Segmentize
+ geography fix.
+ References #3667 for PostGIS 2.4.2
+2017-11-07 18:04 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r16094] liblwgeom/cunit/cu_geodetic.c, liblwgeom/lwgeodetic.c,
+ regress/geography_expected: Replace project-and-entend logic with
+ bisect-and-recurse in geography segmentization.
+ Preserves "mostly equal" segment lengths, and
+ should be more numerically stable.
+ Backport to 2.4.
+ References #3667
+2017-10-31 15:15 Sandro Santilli <strk at kbt.io>
+ * [r16086] configure.ac, liblwgeom/Makefile.in: Make sure target
+ directories are created before copying files to them
+ References #3912 for 2.4 branch
+ References #3916 for 2.4 branch
+2017-10-26 01:07 Regina Obe <lr at pcorp.us>
+ * [r16061] NEWS: Fix zcta5 load - NEWS item
+ References #3917 for PostGIS 2.4.2
+2017-10-26 01:06 Regina Obe <lr at pcorp.us>
+ * [r16060] extras/tiger_geocoder/tiger_loader_2017.sql: Fix zcta5
+ load
+2017-10-21 09:02 Sandro Santilli <strk at kbt.io>
+ * [r16029] .gitignore, GNUmakefile.in, configure.ac,
+ liblwgeom/Makefile.in, loader/Makefile.in, raster/install-sh,
+ raster/loader/Makefile.in, utils/Makefile.in: Put build AUX files
+ under build-aux
+ Cleans and ignore build aux files from new location,
+ and remove spurious install-sh from repository.
+2017-10-20 13:05 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r16018] raster/rt_pg/Makefile.in: Reflect CFLAGS passed into
+ core
+2017-10-20 13:04 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r16017] postgis/Makefile.in: Reflect CFLAGS passed into
+ configure
+2017-10-18 19:28 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r16014] liblwgeom/lwgeom_geos.c, postgis/geobuf.c,
+ postgis/geography_centroid.c, postgis/gserialized_gist_2d.c,
+ postgis/lwgeom_functions_basic.c, postgis/mvt.c: Quiet compile
+ warnings
+2017-10-18 18:46 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r16013] HOWTO_RELEASE, NEWS, README.postgis, Version.config,
+ extensions/upgradeable_versions.mk: Bump forward versions
+2017-10-18 18:32 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r16011] ChangeLog, NEWS, README.postgis, Version.config,
+ doc/release_notes.xml: Prepare for 2.4.1 release
2017-10-17 18:23 Regina Obe <lr at pcorp.us>
* [r16001] doc/introduction.xml:
Modified: branches/2.4/NEWS
--- branches/2.4/NEWS 2017-11-15 18:04:29 UTC (rev 16111)
+++ branches/2.4/NEWS 2017-11-15 18:11:13 UTC (rev 16112)
@@ -1,5 +1,5 @@
-PostGIS 2.4.2dev
-2017/xx/xx
+PostGIS 2.4.2
+2017/11/15
* Bug fixes *
- #3917, Fix zcta5 load
Modified: branches/2.4/README.postgis
--- branches/2.4/README.postgis 2017-11-15 18:04:29 UTC (rev 16111)
+++ branches/2.4/README.postgis 2017-11-15 18:11:13 UTC (rev 16112)
@@ -1,8 +1,8 @@
PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 2.4.2dev
-:Date: 2017-xx-xx
+:Version: 2.4.2
+:Date: 2017-11-15
:Website: http://postgis.net
This distribution contains a module which implements GIS simple features, ties
Modified: branches/2.4/Version.config
--- branches/2.4/Version.config 2017-11-15 18:04:29 UTC (rev 16111)
+++ branches/2.4/Version.config 2017-11-15 18:11:13 UTC (rev 16112)
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=2
POSTGIS_MINOR_VERSION=4
-POSTGIS_MICRO_VERSION=2dev
+POSTGIS_MICRO_VERSION=2
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
Modified: branches/2.4/extensions/upgradeable_versions.mk
--- branches/2.4/extensions/upgradeable_versions.mk 2017-11-15 18:04:29 UTC (rev 16111)
+++ branches/2.4/extensions/upgradeable_versions.mk 2017-11-15 18:11:13 UTC (rev 16112)
@@ -29,6 +29,8 @@
2.3.2 \
2.3.3 \
2.3.4 \
+ 2.3.5 \
2.4.0 \
- 2.4.1
+ 2.4.1 \
+ 2.4.2dev
