[postgis-tickets] [PostGIS] #3930: Precision error in lwgeom_calculate_mbc / point_inside_circle
trac at osgeo.org
Sat Nov 18 09:54:55 PST 2017
Reporter: rundel | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.2
Component: liblwgeom | Version: 2.4.x
Keywords: |
Working on an R wrapper for lwgeom we recent came across a bug with
lwgeom_calculate_mbc where certain geometries on 32 bit systems returned
nan values for center and radius of the mbc. After some debugging the
issue is caused by bad floating point comparison in the
point_inside_circle function. Specifically, distance2d_pt_pt(p, c->center)
> c->radius will erroneously return true when the point p is identical to
one of the support points on 32 bit but not 64 bit systems.
Replacing this test with distance2d_pt_pt(p, c->center) - c->radius >
DBL_EPSILON along with including float.h was able to resolve this issue
for our test case.
Our discussion about the bug and the related pull request for the R
package can be found here: https://github.com/r-spatial/lwgeom/issues/7.
An example of the specific geometry that was producing the error is
attached as WKT.
I am happy to provide a pull request to the github repo if that would be
helpful.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3930>
