[postgis-tickets] [PostGIS] #3931: PG11: Remove TRUE and FALSE
PostGIS trac at osgeo.org
Mon Nov 20 04:09:35 PST 2017
 Reporter:  Algunenano  |      Owner:  pramsey
     Type:  defect      |     Status:  new
 Priority:  high        |  Milestone:  PostGIS 2.5.0
Component:  postgis     |    Version:  trunk
 Keywords:              |
 PostgreSQL has removed `TRUE` and `FALSE` from `c.h` keeping only `true`
 and `false`:
 From http://www.postgresql-archive.org/PostgreSQL-Weekly-News-
 November-19-2017-td5992809.html
 - Remove TRUE and FALSE.  Code should be using true and false.  Existing
 code
   can be changed to those in a backward compatible way.  The definitions
 in the
   ecpg header files are left around to avoid upsetting those users
   unnecessarily.  Reviewed-by: Michael Paquier <[hidden email]>
 https://git.postgresql.org/pg/commitdiff/6337865f36da34e9c89aaa292f976bde6df0b065
 This breaks PostGIS compilation in several places, for example:
 lwgeom_transform.c:170:9: error: ‘FALSE’ undeclared (first use in this
 function); did you mean ‘FILE’?
   return FALSE;
          FILE
 Github's PR: https://github.com/postgis/postgis/pull/172
 I've checked PostgreSQL 9.2 headers and `true` was already available, so
 changing `TRUE` for `true` should be safe.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3931>
