[postgis-tickets] r16116 - PgSQL 11 support, change from FALSE to false, etc.
Paul Ramsey
pramsey at cleverelephant.ca
Mon Nov 20 05:14:03 PST 2017
Author: pramsey
Date: 2017-11-20 05:14:03 -0800 (Mon, 20 Nov 2017)
New Revision: 16116
trunk/libpgcommon/lwgeom_transform.c
trunk/postgis/geography_btree.c
trunk/postgis/geography_measurement.c
trunk/postgis/gserialized_estimate.c
trunk/postgis/gserialized_gist_2d.c
trunk/postgis/gserialized_gist_nd.c
trunk/postgis/lwgeom_btree.c
trunk/postgis/lwgeom_functions_basic.c
trunk/postgis/lwgeom_geos.c
trunk/postgis/lwgeom_geos_prepared.c
trunk/postgis/lwgeom_spheroid.c
Closes #3931, from Ra?\195?\186l Mar?\195?\173n Rodr?\195?\173guez
Modified: trunk/libpgcommon/lwgeom_transform.c
--- trunk/libpgcommon/lwgeom_transform.c 2017-11-19 15:07:17 UTC (rev 16115)
+++ trunk/libpgcommon/lwgeom_transform.c 2017-11-20 13:14:03 UTC (rev 16116)
@@ -167,7 +167,7 @@
* Always return false since this call is mandatory according to tgl
* (see postgis-devel archives July 2007)
- return FALSE;
+ return LW_FALSE;
static void
Modified: trunk/postgis/geography_btree.c
--- trunk/postgis/geography_btree.c 2017-11-19 15:07:17 UTC (rev 16115)
+++ trunk/postgis/geography_btree.c 2017-11-20 13:14:03 UTC (rev 16116)
@@ -52,9 +52,9 @@
GSERIALIZED *g2 = PG_GETARG_GSERIALIZED_P(1);
int cmp = gserialized_cmp(g1, g2);
if (cmp < 0)
- PG_RETURN_BOOL(TRUE);
+ PG_RETURN_BOOL(true);
else
- PG_RETURN_BOOL(FALSE);
+ PG_RETURN_BOOL(false);
@@ -68,9 +68,9 @@
if (cmp <= 0)
else
@@ -84,9 +84,9 @@
if (cmp > 0)
else
@@ -100,9 +100,9 @@
if (cmp >= 0)
else
@@ -116,9 +116,9 @@
if (cmp == 0)
else
Modified: trunk/postgis/geography_measurement.c
--- trunk/postgis/geography_measurement.c 2017-11-19 15:07:17 UTC (rev 16115)
+++ trunk/postgis/geography_measurement.c 2017-11-20 13:14:03 UTC (rev 16116)
@@ -314,7 +314,7 @@
PG_FREE_IF_COPY(g1, 0);
PG_FREE_IF_COPY(g2, 1);
/* Do the brute force calculation if the cached calculation doesn't tick over */
@@ -436,7 +436,7 @@
/* Return FALSE on empty arguments. */
if ( lwgeom_is_empty(lwgeom1) || lwgeom_is_empty(lwgeom2) )
distance = lwgeom_distance_spheroid(lwgeom1, lwgeom2, &s, tolerance);
@@ -451,7 +451,7 @@
if ( distance < 0.0 )
elog(ERROR, "lwgeom_distance_spheroid returned negative!");
PG_RETURN_BOOL(distance <= tolerance);
Modified: trunk/postgis/gserialized_estimate.c
--- trunk/postgis/gserialized_estimate.c 2017-11-19 15:07:17 UTC (rev 16115)
+++ trunk/postgis/gserialized_estimate.c 2017-11-20 13:14:03 UTC (rev 16116)
@@ -499,7 +499,7 @@
target->min[d] = Min(target->min[d], source->min[d]);
target->max[d] = Max(target->max[d], source->max[d]);
- return TRUE;
+ return true;
/** Zero out an ND_BOX */
@@ -507,7 +507,7 @@
nd_box_init(ND_BOX *a)
memset(a, 0, sizeof(ND_BOX));
- return TRUE;
+ return true;
@@ -524,7 +524,7 @@
a->min[d] = FLT_MAX;
a->max[d] = -1 * FLT_MAX;
- return TRUE;
+ return true;
/** Set the values of an #ND_BOX from a #GBOX */
@@ -563,7 +563,7 @@
-* Return TRUE if #ND_BOX a overlaps b, false otherwise.
+* Return true if #ND_BOX a overlaps b, false otherwise.
static int
nd_box_intersects(const ND_BOX *a, const ND_BOX *b, int ndims)
@@ -572,13 +572,13 @@
for ( d = 0; d < ndims; d++ )
if ( (a->min[d] > b->max[d]) || (a->max[d] < b->min[d]) )
- return FALSE;
+ return false;
- return TRUE;
+ return true;
-* Return TRUE if #ND_BOX a contains b, false otherwise.
+* Return true if #ND_BOX a contains b, false otherwise.
static int
nd_box_contains(const ND_BOX *a, const ND_BOX *b, int ndims)
@@ -587,9 +587,9 @@
if ( ! ((a->min[d] < b->min[d]) && (a->max[d] > b->max[d])) )
- return FALSE;
+ return false;
- return TRUE;
+ return true;
@@ -608,7 +608,7 @@
nd_box->min[d] -= size * expansion_factor / 2;
nd_box->max[d] += size * expansion_factor / 2;
- return TRUE;
+ return true;
@@ -644,7 +644,7 @@
nd_ibox->min[d] = Max(nd_ibox->min[d], 0);
nd_ibox->max[d] = Min(nd_ibox->max[d], size-1);
- return TRUE;
+ return true;
@@ -654,7 +654,7 @@
nd_box_ratio(const ND_BOX *b1, const ND_BOX *b2, int ndims)
int d;
- bool covered = TRUE;
+ bool covered = true;
double ivol = 1.0;
double vol2 = 1.0;
double vol1 = 1.0;
@@ -665,7 +665,7 @@
return 0.0; /* Disjoint */
if ( b1->min[d] > b2->min[d] || b1->max[d] < b2->max[d] )
- covered = FALSE;
+ covered = false;
if ( covered )
@@ -793,7 +793,7 @@
distribution[d] = range;
- return TRUE;
+ return true;
@@ -818,10 +818,10 @@
/* That's it, cannot increment any more! */
if ( d == ndims )
- return FALSE;
+ return false;
/* Increment complete! */
- return TRUE;
+ return true;
static ND_STATS*
@@ -889,7 +889,7 @@
if ( ! only_parent )
POSTGIS_DEBUGF(2, "searching whole tree stats for \"%s\"", get_rel_name(table_oid)? get_rel_name(table_oid) : "NULL");
- stats_tuple = SearchSysCache3(STATRELATT, table_oid, att_num, TRUE);
+ stats_tuple = SearchSysCache3(STATRELATT, table_oid, att_num, true);
if ( stats_tuple )
POSTGIS_DEBUGF(2, "found whole tree stats for \"%s\"", get_rel_name(table_oid)? get_rel_name(table_oid) : "NULL");
@@ -924,7 +924,7 @@
* debugging functions are taking human input (table names)
* and columns, so we have to look those up first.
* In case of parent tables whith INHERITS, when "only_parent"
-* is TRUE this function only searchs for stats in the parent
+* is true this function only searchs for stats in the parent
* table ignoring any statistic collected from the children.
static ND_STATS*
@@ -1249,8 +1249,8 @@
get_rel_name(relid1) ? get_rel_name(relid1) : "NULL", relid1, get_rel_name(relid2) ? get_rel_name(relid2) : "NULL", relid2);
/* Pull the stats from the stats system. */
- stats1 = pg_get_nd_stats(relid1, var1->varattno, mode, FALSE);
- stats2 = pg_get_nd_stats(relid2, var2->varattno, mode, FALSE);
+ stats1 = pg_get_nd_stats(relid1, var1->varattno, mode, false);
+ stats2 = pg_get_nd_stats(relid2, var2->varattno, mode, false);
/* If we can't get stats, we have to stop here! */
if ( ! stats1 )
@@ -1803,7 +1803,7 @@
* It will need to return a stats builder function reference
* and a "minimum" sample rows to feed it.
* If we want analisys to be completely skipped we can return
-* FALSE and leave output vals untouched.
+* false and leave output vals untouched.
* What we know from this call is:
@@ -1992,7 +1992,7 @@
char *str;
text *json;
int mode = 2; /* default to 2D mode */
- bool only_parent = FALSE; /* default to whole tree stats */
+ bool only_parent = false; /* default to whole tree stats */
/* Check if we've been asked to not use 2d mode */
if ( ! PG_ARGISNULL(2) )
@@ -2036,7 +2036,7 @@
mode = text_p_get_mode(PG_GETARG_TEXT_P(3));
/* Retrieve the stats object */
- nd_stats = pg_get_nd_stats_by_name(table_oid, att_text, mode, FALSE);
+ nd_stats = pg_get_nd_stats_by_name(table_oid, att_text, mode, false);
if ( ! nd_stats )
elog(ERROR, "stats for \"%s.%s\" do not exist", get_rel_name(table_oid), text2cstring(att_text));
@@ -2072,8 +2072,8 @@
- nd_stats1 = pg_get_nd_stats_by_name(table_oid1, att_text1, mode, FALSE);
- nd_stats2 = pg_get_nd_stats_by_name(table_oid2, att_text2, mode, FALSE);
+ nd_stats1 = pg_get_nd_stats_by_name(table_oid1, att_text1, mode, false);
+ nd_stats2 = pg_get_nd_stats_by_name(table_oid2, att_text2, mode, false);
if ( ! nd_stats1 )
elog(ERROR, "stats for \"%s.%s\" do not exist", get_rel_name(table_oid1), text2cstring(att_text1));
@@ -2242,7 +2242,7 @@
Oid tbl_oid;
ND_STATS *nd_stats;
GBOX *gbox;
if ( PG_NARGS() == 4 )
Modified: trunk/postgis/gserialized_gist_2d.c
--- trunk/postgis/gserialized_gist_2d.c 2017-11-19 15:07:17 UTC (rev 16115)
+++ trunk/postgis/gserialized_gist_2d.c 2017-11-20 13:14:03 UTC (rev 16116)
@@ -182,7 +182,7 @@
POSTGIS_DEBUGF(5, "calculating intersection of %s with %s", box2df_to_string(a), box2df_to_string(b));
if( a == NULL || b == NULL || n == NULL )
- return FALSE;
+ return false;
n->xmax = Min(a->xmax, b->xmax);
n->ymax = Min(a->ymax, b->ymax);
@@ -192,9 +192,9 @@
POSTGIS_DEBUGF(5, "intersection is %s", box2df_to_string(n));
if ( (n->xmax < n->xmin) || (n->ymax < n->ymin) )
- return FALSE;
+ return false;
- return TRUE;
+ return true;
#endif
@@ -315,33 +315,33 @@
static bool box2df_overlaps(const BOX2DF *a, const BOX2DF *b)
- if ( ! a || ! b ) return FALSE; /* TODO: might be smarter for EMPTY */
+ if ( ! a || ! b ) return false; /* TODO: might be smarter for EMPTY */
if ( (a->xmin > b->xmax) || (b->xmin > a->xmax) ||
(a->ymin > b->ymax) || (b->ymin > a->ymax) )
- return FALSE;
+ return false;
- return TRUE;
+ return true;
bool box2df_contains(const BOX2DF *a, const BOX2DF *b)
if ( (a->xmin > b->xmin) || (a->xmax < b->xmax) ||
(a->ymin > b->ymin) || (a->ymax < b->ymax) )
- return FALSE;
+ return false;
- return TRUE;
+ return true;
static bool box2df_within(const BOX2DF *a, const BOX2DF *b)
POSTGIS_DEBUG(5, "entered function");
return box2df_contains(b,a);
@@ -353,21 +353,21 @@
if ( (a->xmin != b->xmin) || (a->xmax != b->xmax) ||
(a->ymin != b->ymin) || (a->ymax != b->ymax) )
- return FALSE;
+ return false;
- return TRUE;
+ return true;
} else if ( a || b ) {
/* one empty, one not */
- return FALSE;
+ return false;
} else {
/* both empty */
- return TRUE;
+ return true;
static bool box2df_overleft(const BOX2DF *a, const BOX2DF *b)
/* a.xmax <= b.xmax */
return a->xmax <= b->xmax;
@@ -375,7 +375,7 @@
static bool box2df_left(const BOX2DF *a, const BOX2DF *b)
/* a.xmax < b.xmin */
return a->xmax < b->xmin;
@@ -383,7 +383,7 @@
static bool box2df_right(const BOX2DF *a, const BOX2DF *b)
/* a.xmin > b.xmax */
return a->xmin > b->xmax;
@@ -391,7 +391,7 @@
static bool box2df_overright(const BOX2DF *a, const BOX2DF *b)
/* a.xmin >= b.xmin */
return a->xmin >= b->xmin;
@@ -399,7 +399,7 @@
static bool box2df_overbelow(const BOX2DF *a, const BOX2DF *b)
/* a.ymax <= b.ymax */
return a->ymax <= b->ymax;
@@ -407,7 +407,7 @@
static bool box2df_below(const BOX2DF *a, const BOX2DF *b)
/* a.ymax < b.ymin */
return a->ymax < b->ymin;
@@ -415,7 +415,7 @@
static bool box2df_above(const BOX2DF *a, const BOX2DF *b)
/* a.ymin > b.ymax */
return a->ymin > b->ymax;
@@ -423,7 +423,7 @@
static bool box2df_overabove(const BOX2DF *a, const BOX2DF *b)
/* a.ymin >= b.ymin */
return a->ymin >= b->ymin;
@@ -685,18 +685,18 @@
POSTGIS_DEBUG(3, "entered function");
if ( gserialized_datum_predicate_box2df_geom_2d((BOX2DF*)PG_GETARG_POINTER(0), PG_GETARG_DATUM(1), box2df_contains) == LW_TRUE )
PG_FUNCTION_INFO_V1(gserialized_contains_box2df_box2df_2d);
Datum gserialized_contains_box2df_box2df_2d(PG_FUNCTION_ARGS)
if ( box2df_contains((BOX2DF *)PG_GETARG_POINTER(0), (BOX2DF *)PG_GETARG_POINTER(1)))
PG_FUNCTION_INFO_V1(gserialized_within_box2df_geom_2d);
@@ -704,18 +704,18 @@
if ( gserialized_datum_predicate_box2df_geom_2d((BOX2DF*)PG_GETARG_POINTER(0), PG_GETARG_DATUM(1), box2df_within) == LW_TRUE )
PG_FUNCTION_INFO_V1(gserialized_within_box2df_box2df_2d);
Datum gserialized_within_box2df_box2df_2d(PG_FUNCTION_ARGS)
if ( box2df_within((BOX2DF *)PG_GETARG_POINTER(0), (BOX2DF *)PG_GETARG_POINTER(1)))
PG_FUNCTION_INFO_V1(gserialized_overlaps_box2df_geom_2d);
@@ -723,18 +723,18 @@
if ( gserialized_datum_predicate_box2df_geom_2d((BOX2DF*)PG_GETARG_POINTER(0), PG_GETARG_DATUM(1), box2df_overlaps) == LW_TRUE )
PG_FUNCTION_INFO_V1(gserialized_overlaps_box2df_box2df_2d);
Datum gserialized_overlaps_box2df_box2df_2d(PG_FUNCTION_ARGS)
if ( box2df_overlaps((BOX2DF *)PG_GETARG_POINTER(0), (BOX2DF *)PG_GETARG_POINTER(1)))
#endif
@@ -786,9 +786,9 @@
Datum gserialized_same_2d(PG_FUNCTION_ARGS)
if ( gserialized_datum_predicate_2d(PG_GETARG_DATUM(0), PG_GETARG_DATUM(1), box2df_equals) == LW_TRUE )
PG_FUNCTION_INFO_V1(gserialized_within_2d);
@@ -796,9 +796,9 @@
if ( gserialized_datum_predicate_2d(PG_GETARG_DATUM(0), PG_GETARG_DATUM(1), box2df_within) == LW_TRUE )
PG_FUNCTION_INFO_V1(gserialized_contains_2d);
@@ -806,90 +806,90 @@
if ( gserialized_datum_predicate_2d(PG_GETARG_DATUM(0), PG_GETARG_DATUM(1), box2df_contains) == LW_TRUE )
PG_FUNCTION_INFO_V1(gserialized_overlaps_2d);
Datum gserialized_overlaps_2d(PG_FUNCTION_ARGS)
if ( gserialized_datum_predicate_2d(PG_GETARG_DATUM(0), PG_GETARG_DATUM(1), box2df_overlaps) == LW_TRUE )
PG_FUNCTION_INFO_V1(gserialized_left_2d);
Datum gserialized_left_2d(PG_FUNCTION_ARGS)
if ( gserialized_datum_predicate_2d(PG_GETARG_DATUM(0), PG_GETARG_DATUM(1), box2df_left) == LW_TRUE )
PG_FUNCTION_INFO_V1(gserialized_right_2d);
Datum gserialized_right_2d(PG_FUNCTION_ARGS)
if ( gserialized_datum_predicate_2d(PG_GETARG_DATUM(0), PG_GETARG_DATUM(1), box2df_right) == LW_TRUE )
PG_FUNCTION_INFO_V1(gserialized_above_2d);
Datum gserialized_above_2d(PG_FUNCTION_ARGS)
if ( gserialized_datum_predicate_2d(PG_GETARG_DATUM(0), PG_GETARG_DATUM(1), box2df_above) == LW_TRUE )
PG_FUNCTION_INFO_V1(gserialized_below_2d);
Datum gserialized_below_2d(PG_FUNCTION_ARGS)
if ( gserialized_datum_predicate_2d(PG_GETARG_DATUM(0), PG_GETARG_DATUM(1), box2df_below) == LW_TRUE )
PG_FUNCTION_INFO_V1(gserialized_overleft_2d);
Datum gserialized_overleft_2d(PG_FUNCTION_ARGS)
if ( gserialized_datum_predicate_2d(PG_GETARG_DATUM(0), PG_GETARG_DATUM(1), box2df_overleft) == LW_TRUE )
PG_FUNCTION_INFO_V1(gserialized_overright_2d);
Datum gserialized_overright_2d(PG_FUNCTION_ARGS)
if ( gserialized_datum_predicate_2d(PG_GETARG_DATUM(0), PG_GETARG_DATUM(1), box2df_overright) == LW_TRUE )
PG_FUNCTION_INFO_V1(gserialized_overabove_2d);
Datum gserialized_overabove_2d(PG_FUNCTION_ARGS)
if ( gserialized_datum_predicate_2d(PG_GETARG_DATUM(0), PG_GETARG_DATUM(1), box2df_overabove) == LW_TRUE )
PG_FUNCTION_INFO_V1(gserialized_overbelow_2d);
Datum gserialized_overbelow_2d(PG_FUNCTION_ARGS)
if ( gserialized_datum_predicate_2d(PG_GETARG_DATUM(0), PG_GETARG_DATUM(1), box2df_overbelow) == LW_TRUE )
@@ -934,7 +934,7 @@
POSTGIS_DEBUG(4, "[GIST] leafkey is null");
gistentryinit(*entry_out, (Datum) 0, entry_in->rel,
- entry_in->page, entry_in->offset, FALSE);
+ entry_in->page, entry_in->offset, false);
POSTGIS_DEBUG(4, "[GIST] returning copy of input");
PG_RETURN_POINTER(entry_out);
@@ -964,7 +964,7 @@
/* Prepare GISTENTRY for return. */
gistentryinit(*entry_out, PointerGetDatum(box2df_copy(&bbox_out)),
- entry_in->rel, entry_in->page, entry_in->offset, FALSE);
+ entry_in->rel, entry_in->page, entry_in->offset, false);
/* Return GISTENTRY. */
POSTGIS_DEBUG(4, "[GIST] 'compress' function complete");
@@ -1044,7 +1044,7 @@
break;
default:
- retval = FALSE;
+ retval = false;
return (retval);
@@ -1106,7 +1106,7 @@
break;
default:
- retval = FALSE;
+ retval = false;
return (retval);
@@ -1139,21 +1139,21 @@
if ( DatumGetPointer(PG_GETARG_DATUM(1)) == NULL )
POSTGIS_DEBUG(4, "[GIST] null query pointer (!?!), returning false");
- PG_RETURN_BOOL(FALSE); /* NULL query! This is screwy! */
+ PG_RETURN_BOOL(false); /* NULL query! This is screwy! */
/* Quick sanity check on entry key. */
if ( DatumGetPointer(entry->key) == NULL )
POSTGIS_DEBUG(4, "[GIST] null index entry, returning false");
- PG_RETURN_BOOL(FALSE); /* NULL entry! */
+ PG_RETURN_BOOL(false); /* NULL entry! */
/* Null box should never make this far. */
if ( gserialized_datum_get_box2df_p(PG_GETARG_DATUM(1), &query_gbox_index) == LW_FAILURE )
POSTGIS_DEBUG(4, "[GIST] null query_gbox_index!");
/* Treat leaf node tests different from internal nodes */
@@ -2351,12 +2351,12 @@
float sizeLR, sizeBT;
BOX2DF interLR, interBT;
- if ( box2df_intersection(unionL, unionR, &interLR) == FALSE )
+ if ( box2df_intersection(unionL, unionR, &interLR) == false )
sizeLR = 0.0;
else
sizeLR = box2df_size(&interLR);
- if ( box2df_intersection(unionB, unionT, &interBT) == FALSE )
+ if ( box2df_intersection(unionB, unionT, &interBT) == false )
sizeBT = 0.0;
else
sizeBT = box2df_size(&interBT);
Modified: trunk/postgis/gserialized_gist_nd.c
--- trunk/postgis/gserialized_gist_nd.c 2017-11-19 15:07:17 UTC (rev 16115)
+++ trunk/postgis/gserialized_gist_nd.c 2017-11-20 13:14:03 UTC (rev 16116)
@@ -159,8 +159,8 @@
size_t size = VARSIZE(a) - VARHDRSZ;
/* "unknown" gidx objects have a too-small size of one float */
if ( size <= 0.0 )
- return TRUE;
- return FALSE;
+ return true;
+ return false;
static inline void gidx_set_unknown(GIDX *a)
@@ -420,10 +420,10 @@
int ndims_b;
- if ( (a == NULL) || (b == NULL) ) return FALSE;
+ if ( (a == NULL) || (b == NULL) ) return false;
if ( gidx_is_unknown(a) || gidx_is_unknown(b) )
- return FALSE;
+ return false;
/* Ensure 'a' has the most dimensions. */
gidx_dimensionality_check(&a, &b);
@@ -434,12 +434,12 @@
for ( i = 0; i < ndims_b; i++ )
if ( GIDX_GET_MIN(a,i) > GIDX_GET_MAX(b,i) )
- return FALSE;
+ return false;
if ( GIDX_GET_MIN(b,i) > GIDX_GET_MAX(a,i) )
- return FALSE;
+ return false;
- return TRUE;
+ return true;
@@ -453,10 +453,10 @@
- return FALSE;
+ return false;
dims_a = GIDX_NDIMS(a);
dims_b = GIDX_NDIMS(b);
@@ -470,9 +470,9 @@
for (i = dims_a; i < dims_b; i++)
if ( GIDX_GET_MIN(b,i) != 0 )
- return FALSE;
+ return false;
if ( GIDX_GET_MAX(b,i) != 0 )
- return FALSE;
+ return false;
@@ -480,12 +480,12 @@
for (i = 0; i < Min(dims_a, dims_b); i++)
if ( GIDX_GET_MIN(a,i) > GIDX_GET_MIN(b,i) )
- return FALSE;
+ return false;
if ( GIDX_GET_MAX(a,i) < GIDX_GET_MAX(b,i) )
- return FALSE;
+ return false;
- return TRUE;
+ return true;
@@ -499,14 +499,14 @@
- if ( (a == NULL) && (b == NULL) ) return TRUE;
+ if ( (a == NULL) && (b == NULL) ) return true;
if ( gidx_is_unknown(a) && gidx_is_unknown(b) )
- return TRUE;
+ return true;
- return FALSE;
+ return false;
@@ -515,19 +515,19 @@
for (i = 0; i < GIDX_NDIMS(b); i++)
if ( GIDX_GET_MIN(a,i) != GIDX_GET_MIN(b,i) )
- return FALSE;
+ return false;
if ( GIDX_GET_MAX(a,i) != GIDX_GET_MAX(b,i) )
- return FALSE;
+ return false;
/* For all unshared dimensions min(a) == 0.0, max(a) == 0.0 */
for (i = GIDX_NDIMS(b); i < GIDX_NDIMS(a); i++)
if ( GIDX_GET_MIN(a,i) != 0.0 )
- return FALSE;
+ return false;
if ( GIDX_GET_MAX(a,i) != 0.0 )
- return FALSE;
+ return false;
- return TRUE;
+ return true;
@@ -924,10 +924,10 @@
if ( gserialized_datum_predicate(PG_GETARG_DATUM(1), PG_GETARG_DATUM(0), gidx_contains) == LW_TRUE )
#if POSTGIS_PGSQL_VERSION > 94
@@ -941,9 +941,9 @@
GIDX *gidx = (GIDX *)PG_GETARG_POINTER(0);
if ( gserialized_datum_predicate_geom_gidx(PG_GETARG_DATUM(1), gidx, gidx_contains) == LW_TRUE )
@@ -954,9 +954,9 @@
Datum gserialized_gidx_gidx_within(PG_FUNCTION_ARGS)
if ( gidx_contains((GIDX *)PG_GETARG_POINTER(1), (GIDX *)PG_GETARG_POINTER(0)))
#endif
@@ -969,10 +969,10 @@
if ( gserialized_datum_predicate(PG_GETARG_DATUM(0),PG_GETARG_DATUM(1), gidx_contains) == LW_TRUE )
@@ -986,9 +986,9 @@
if ( gserialized_datum_predicate_gidx_geom(gidx, PG_GETARG_DATUM(1), gidx_contains) == LW_TRUE )
@@ -999,9 +999,9 @@
Datum gserialized_gidx_gidx_contains(PG_FUNCTION_ARGS)
if ( gidx_contains((GIDX *)PG_GETARG_POINTER(0), (GIDX *)PG_GETARG_POINTER(1)))
PG_FUNCTION_INFO_V1(gserialized_gidx_geom_same);
@@ -1010,18 +1010,18 @@
if ( gserialized_datum_predicate_gidx_geom(gidx, PG_GETARG_DATUM(1), gidx_equals) == LW_TRUE )
PG_FUNCTION_INFO_V1(gserialized_gidx_gidx_same);
Datum gserialized_gidx_gidx_same(PG_FUNCTION_ARGS)
if ( gidx_equals((GIDX *)PG_GETARG_POINTER(0), (GIDX *)PG_GETARG_POINTER(1)) )
#endif
@@ -1034,10 +1034,10 @@
if ( gserialized_datum_predicate(PG_GETARG_DATUM(0),PG_GETARG_DATUM(1), gidx_overlaps) == LW_TRUE )
@@ -1050,9 +1050,9 @@
if ( gserialized_datum_predicate_gidx_geom(gidx, PG_GETARG_DATUM(1), gidx_overlaps) == LW_TRUE )
PG_FUNCTION_INFO_V1(gserialized_gidx_geom_overlaps);
@@ -1061,18 +1061,18 @@
PG_FUNCTION_INFO_V1(gserialized_gidx_gidx_overlaps);
Datum gserialized_gidx_gidx_overlaps(PG_FUNCTION_ARGS)
if ( gidx_overlaps((GIDX *)PG_GETARG_POINTER(0), (GIDX *)PG_GETARG_POINTER(1)) )
#endif
@@ -1119,7 +1119,7 @@
@@ -1135,7 +1135,7 @@
gidx_set_unknown(bbox_out);
gistentryinit(*entry_out, PointerGetDatum(gidx_copy(bbox_out)),
- entry_in->offset, FALSE);
+ entry_in->offset, false);
@@ -1152,7 +1152,7 @@
@@ -1162,7 +1162,7 @@
@@ -1208,7 +1208,7 @@
retval = (bool) gidx_contains(query, key);
break;
default:
- retval = FALSE;
+ retval = false;
return (retval);
@@ -1239,7 +1239,7 @@
retval = (bool) gidx_overlaps(key, query);
break;
default:
- retval = FALSE;
+ retval = false;
return (retval);
@@ -1273,21 +1273,21 @@
if ( gserialized_datum_get_gidx_p(PG_GETARG_DATUM(1), query_gbox_index) == LW_FAILURE )
@@ -1612,9 +1612,9 @@
POSTGIS_DEBUGF(4, "[GIST] checking split ratio (%d, %d)", x, y);
if ( (y == 0) || (((float)x / (float)y) < LIMIT_RATIO) ||
(x == 0) || (((float)y / (float)x) < LIMIT_RATIO) )
- return TRUE;
+ return true;
- return FALSE;
+ return false;
static bool gserialized_gist_picksplit_badratios(int *pos, int dims)
@@ -1622,10 +1622,10 @@
int i;
for ( i = 0; i < dims; i++ )
- if ( gserialized_gist_picksplit_badratio(pos[2*i],pos[2*i+1]) == FALSE )
- return FALSE;
+ if ( gserialized_gist_picksplit_badratio(pos[2*i],pos[2*i+1]) == false )
+ return false;
- return TRUE;
+ return true;
@@ -1731,11 +1731,11 @@
GISTENTRY oldUnion, addon;
gistentryinit(oldUnion, (v->spl_ldatum_exists) ? v->spl_ldatum : v->spl_rdatum,
- NULL, NULL, InvalidOffsetNumber, FALSE);
+ NULL, NULL, InvalidOffsetNumber, false);
- gistentryinit(addon, PointerGetDatum(*union1), NULL, NULL, InvalidOffsetNumber, FALSE);
+ gistentryinit(addon, PointerGetDatum(*union1), NULL, NULL, InvalidOffsetNumber, false);
DirectFunctionCall3(gserialized_gist_penalty, PointerGetDatum(&oldUnion), PointerGetDatum(&addon), PointerGetDatum(&p1));
- gistentryinit(addon, PointerGetDatum(*union2), NULL, NULL, InvalidOffsetNumber, FALSE);
+ gistentryinit(addon, PointerGetDatum(*union2), NULL, NULL, InvalidOffsetNumber, false);
DirectFunctionCall3(gserialized_gist_penalty, PointerGetDatum(&oldUnion), PointerGetDatum(&addon), PointerGetDatum(&p2));
POSTGIS_DEBUGF(4, "[GIST] p1 / p2 == %.12g / %.12g", p1, p2);
@@ -1890,7 +1890,7 @@
** sides of the page union box can occasionally all end up in one place, leading
** to this condition.
- if ( gserialized_gist_picksplit_badratios(pos,ndims_pageunion) == TRUE )
+ if ( gserialized_gist_picksplit_badratios(pos,ndims_pageunion) == true )
** Instead we split on center points and see if we do better.
@@ -1943,7 +1943,7 @@
/* Do we have a good disposition now? If not, screw it, just cut the node in half. */
POSTGIS_DEBUG(4, "[GIST] picksplit still cannot find a good split! just cutting the node in half");
gserialized_gist_picksplit_fallback(entryvec, v);
Modified: trunk/postgis/lwgeom_btree.c
--- trunk/postgis/lwgeom_btree.c 2017-11-19 15:07:17 UTC (rev 16115)
+++ trunk/postgis/lwgeom_btree.c 2017-11-20 13:14:03 UTC (rev 16116)
@@ -56,9 +56,9 @@
if (cmp < 0)
else
PG_FUNCTION_INFO_V1(lwgeom_le);
@@ -70,9 +70,9 @@
if (cmp == 0)
else
PG_FUNCTION_INFO_V1(lwgeom_eq);
@@ -84,9 +84,9 @@
if (cmp == 0)
else
PG_FUNCTION_INFO_V1(lwgeom_ge);
@@ -98,9 +98,9 @@
if (cmp >= 0)
else
PG_FUNCTION_INFO_V1(lwgeom_gt);
@@ -112,9 +112,9 @@
if (cmp > 0)
else
PG_FUNCTION_INFO_V1(lwgeom_cmp);
Modified: trunk/postgis/lwgeom_functions_basic.c
--- trunk/postgis/lwgeom_functions_basic.c 2017-11-19 15:07:17 UTC (rev 16115)
+++ trunk/postgis/lwgeom_functions_basic.c 2017-11-20 13:14:03 UTC (rev 16116)
@@ -209,16 +209,16 @@
PG_FUNCTION_INFO_V1(postgis_uses_stats);
Datum postgis_uses_stats(PG_FUNCTION_ARGS)
PG_FUNCTION_INFO_V1(postgis_autocache_bbox);
Datum postgis_autocache_bbox(PG_FUNCTION_ARGS)
#ifdef POSTGIS_AUTOCACHE_BBOX
#else
#endif
@@ -2030,14 +2030,14 @@
- PG_RETURN_BOOL(FALSE); /* different types */
+ PG_RETURN_BOOL(false); /* different types */
if ( gserialized_get_zm(g1) != gserialized_get_zm(g2) )
- PG_RETURN_BOOL(FALSE); /* different dimensions */
+ PG_RETURN_BOOL(false); /* different dimensions */
/* ok, deserialize. */
@@ -2590,7 +2590,7 @@
(g1_bvol.ymin > geom2->bbox->ymax) ||
(g1_bvol.ymax < geom2->bbox->ymin) )
- PG_RETURN_BOOL(FALSE); /*bbox not overlap */
+ PG_RETURN_BOOL(false); /*bbox not overlap */
Modified: trunk/postgis/lwgeom_geos.c
--- trunk/postgis/lwgeom_geos.c 2017-11-19 15:07:17 UTC (rev 16115)
+++ trunk/postgis/lwgeom_geos.c 2017-11-20 13:14:03 UTC (rev 16116)
@@ -1565,7 +1565,7 @@
* notice now that we have ST_isValidReason ?
lwpgnotice("%s", lwgeom_geos_errmsg);
result = GEOSisValid(g1);
@@ -1749,7 +1749,7 @@
if ( ! gbox_overlaps_2d(&box1, &box2) )
@@ -1819,7 +1819,7 @@
if ( ! gbox_contains_2d(&box1, &box2) )
@@ -1964,7 +1964,7 @@
gserialized_get_gbox_p(geom2, &box2) )
initGEOS(lwpgnotice, lwgeom_geos_error);
@@ -2049,7 +2049,7 @@
@@ -2198,7 +2198,7 @@
if ( ! gbox_contains_2d(&box2, &box1) )
POSTGIS_DEBUG(3, "bounding box short-circuit missed.");
@@ -2323,7 +2323,7 @@
if ( gbox_overlaps_2d(&box1, &box2) == LW_FALSE )
@@ -2389,7 +2389,7 @@
@@ -2534,7 +2534,7 @@
@@ -2601,7 +2601,7 @@
@@ -2793,7 +2793,7 @@
/* Empty == Empty */
if ( gserialized_is_empty(geom1) && gserialized_is_empty(geom2) )
* short-circuit: If geom1 and geom2 do not have the same bounding box
@@ -2804,7 +2804,7 @@
if ( gbox_same_2d_float(&box1, &box2) == LW_FALSE )
@@ -2813,7 +2813,7 @@
* TRUE. This is much faster than doing the comparison using GEOS.
if (VARSIZE(geom1) == VARSIZE(geom2) && !memcmp(geom1, geom2, VARSIZE(geom1))) {
@@ -2864,7 +2864,7 @@
geom = PG_GETARG_GSERIALIZED_P(0);
if ( gserialized_is_empty(geom) )
lwgeom_in = lwgeom_from_gserialized(geom);
result = lwgeom_is_simple(lwgeom_in);
@@ -2889,7 +2889,7 @@
/* Empty things can't close */
Modified: trunk/postgis/lwgeom_geos_prepared.c
--- trunk/postgis/lwgeom_geos_prepared.c 2017-11-19 15:07:17 UTC (rev 16115)
+++ trunk/postgis/lwgeom_geos_prepared.c 2017-11-20 13:14:03 UTC (rev 16116)
@@ -174,7 +174,7 @@
- return FALSE;
+ return LW_FALSE;
static void
Modified: trunk/postgis/lwgeom_spheroid.c
--- trunk/postgis/lwgeom_spheroid.c 2017-11-19 15:07:17 UTC (rev 16115)
+++ trunk/postgis/lwgeom_spheroid.c 2017-11-20 13:14:03 UTC (rev 16116)
@@ -534,7 +534,7 @@
Datum LWGEOM_distance_ellipsoid(PG_FUNCTION_ARGS)
PG_RETURN_DATUM(DirectFunctionCall4(geometry_distance_spheroid,
- PG_GETARG_DATUM(0), PG_GETARG_DATUM(1), PG_GETARG_DATUM(2), BoolGetDatum(TRUE)));
+ PG_GETARG_DATUM(0), PG_GETARG_DATUM(1), PG_GETARG_DATUM(2), BoolGetDatum(true)));
PG_FUNCTION_INFO_V1(LWGEOM_distance_sphere);
@@ -547,6 +547,6 @@
s.a = s.b = s.radius;
- PG_GETARG_DATUM(0), PG_GETARG_DATUM(1), PointerGetDatum(&s), BoolGetDatum(FALSE)));
+ PG_GETARG_DATUM(0), PG_GETARG_DATUM(1), PointerGetDatum(&s), BoolGetDatum(false)));
