[postgis-tickets] r16117 - Always include revision when defined (even if 0)
Sandro Santilli strk at kbt.io
Fri Nov 24 23:38:52 PST 2017
Author: strk
Date: 2017-11-24 23:38:52 -0800 (Fri, 24 Nov 2017)
New Revision: 16117
   trunk/postgis/sqldefines.h.in
Should fix #3863 (scripts always need upgrade)
Modified: trunk/postgis/sqldefines.h.in
--- trunk/postgis/sqldefines.h.in	2017-11-20 13:14:03 UTC (rev 16116)
+++ trunk/postgis/sqldefines.h.in	2017-11-25 07:38:52 UTC (rev 16117)
@@ -28,7 +28,7 @@
 #define _POSTGIS_SQL_SELECT_POSTGIS_BUILD_DATE 'SELECT ''@POSTGIS_BUILD_DATE@''::text AS version'
 #define _POSTGIS_SQL_SELECT_POSTGIS_PGSQL_VERSION 'SELECT ''@POSTGIS_PGSQL_VERSION@''::text AS version'
-#if POSTGIS_SVN_REVISION
+#ifdef POSTGIS_SVN_REVISION
 #define _POSTGIS_SQL_SELECT_POSTGIS_SCRIPTS_VERSION $$ SELECT '@POSTGIS_SCRIPTS_VERSION@'::text || ' r' || POSTGIS_SVN_REVISION::text AS version $$
 #else
 #define _POSTGIS_SQL_SELECT_POSTGIS_SCRIPTS_VERSION $$ SELECT '@POSTGIS_SCRIPTS_VERSION@'::text AS version $$
