[postgis-tickets] [PostGIS] #3936: Setting up bessie iconv errors FreeBSD
PostGIS trac at osgeo.org
Sun Nov 26 18:02:51 PST 2017
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  medium     |  Milestone:  Management 2.0
 Component:  buildbots  |    Version:  2.4.x
Resolution:             |   Keywords:
Comment (by robe):
 As noted on mailing list Bessie has 2 iconvs.
 One located in /usr/bin/iconv
 /usr/bin/iconv --version
 outputs
 iconv: unrecognized option `--version'
 Usage:  iconv [-cs] -f <from_code> -t <to_code> [file ...]
         iconv -f <from_code> [-cs] [-t <to_code>] [file ...]
         iconv -t <to_code> [-cs] [-f <from_code>] [file ...]
         iconv -l
 and another
 /usr/local/bin/iconv --version
 outputs
 iconv (GNU libiconv 1.14)
 Copyright (C) 2000-2011 Free Software Foundation, Inc.
 License GPLv3+: GNU GPL version 3 or later
 <http://gnu.org/licenses/gpl.html>
 This is free software: you are free to change and redistribute it.
 There is NO WARRANTY, to the extent permitted by law.
 Written by Bruno Haible.
 The /usr/local/bin/iconv seems to respond to usual command --version.
 The other does not.
 Seems the default when I call
 iconv is the  /usr/bin/iconv
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3936#comment:3>
