[postgis-tickets] [PostGIS] #3936: Setting up bessie iconv errors FreeBSD
trac at osgeo.org
Tue Nov 28 13:46:19 PST 2017
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.5.0
Component: buildbots | Version: 2.4.x
Resolution: | Keywords:
Comment (by robe):
hmm meant pkg install
pkg info libiconv
is pretty informative.
libiconv-1.14_11
Version : 1.14_11
Installed on : Sun Nov 26 09:52:52 2017 UTC
Origin : converters/libiconv
Architecture : FreeBSD:11:amd64
Prefix : /usr/local
Categories : devel converters
Licenses : GPLv3
Maintainer : gnome at FreeBSD.org
WWW : http://www.gnu.org/software/libiconv/
Comment : Character set conversion library
Options :
DOCS : on
ENCODINGS : on
PATCHES : off
Shared Libs provided:
libiconv.so.2
libcharset.so.1
Annotations :
repo_type : binary
repository : FreeBSD
Flat size : 2.21MiB
aha you are right, the /usr/local/bin is in PATH but not include or lib
folders
though why does -liconv manage to find the libiconv though if I don't
explicitly add to ./configure
or is it just dumb luck because proj is installed in /usr/local/lib so
doing --with-proj makes the compile work
echo $PATH
outputs:
/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/sbin:/usr/local/bin:/home/robe/bin
I think I got to start experimenting with Jails next and run all jobs in a
jail.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3936#comment:10>
