[postgis-tickets] [PostGIS] #2645: ST_LineInterpolatePoint incorrect output for 3D linestring
PostGIS trac at osgeo.org
Wed Nov 29 06:36:28 PST 2017
  Reporter:  bencaradocdavies  |      Owner:  pramsey
      Type:  defect            |     Status:  closed
  Priority:  critical          |  Milestone:  PostGIS Fund Me
 Component:  postgis           |    Version:  2.1.x
Resolution:  wontfix           |   Keywords:
Comment (by robe):
 Vincent,
 I was going to rewrite this ticket, but given the long comment history and
 the fact you fixed by implementing a new function, can you instead create
 a new ticket.
 Just call the title ST_3DLineInterpolatePoint and reattach a revised
 patch.
 At a glance one thing that needs changing in your patch is availability.
 Since it's a new function, availability should be changed from 2.4.0 to:
 2.5.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2645#comment:10>
