[postgis-tickets] r16128 - Doco on "enhancement" per robe, closes #3097
Paul Ramsey
pramsey at cleverelephant.ca
Thu Nov 30 12:52:57 PST 2017
Author: pramsey
Date: 2017-11-30 12:52:56 -0800 (Thu, 30 Nov 2017)
New Revision: 16128
trunk/NEWS
trunk/doc/reference_processing.xml
Modified: trunk/NEWS
--- trunk/NEWS 2017-11-30 19:18:03 UTC (rev 16127)
+++ trunk/NEWS 2017-11-30 20:52:56 UTC (rev 16128)
@@ -24,6 +24,7 @@
#1855, #1946, #3718, #3838
- #3234, Do not accept EMPTY points as topology nodes (Sandro Santilli)
- #1014, Hashable geometry, allowing direct use in CTE signatures (Paul Ramsey)
+ - #3097, Really allow MULTILINESTRING blades in ST_Split() (Paul Ramsey)
PostGIS 2.4.0
Modified: trunk/doc/reference_processing.xml
--- trunk/doc/reference_processing.xml 2017-11-30 19:18:03 UTC (rev 16127)
+++ trunk/doc/reference_processing.xml 2017-11-30 20:52:56 UTC (rev 16128)
@@ -3084,6 +3084,8 @@
<para>Availability: 2.0.0</para>
<para>Changed: 2.2.0 support for splitting a line by a multiline, a multipoint or (multi)polygon boundary was introduced.</para>
+ <para>Enhanced: 2.5.0 support for MULTILINESTRING split blades.</para>
<note><para>To improve the robustness of ST_Split it may be convenient to <xref linkend="ST_Snap"/> the input to the blade in advance using a very low tolerance. Otherwise the internally used coordinate grid may cause tolerance problems, where coordinates of input and blade do not fall onto each other and the input is not being split correctly (see <ulink url="http://trac.osgeo.org/postgis/ticket/2192">#2192</ulink>).</para></note>
<note><para>
