[postgis-tickets] r16132 - Support google line encodings that include a backslash character (References #3713)
Paul Ramsey
pramsey at cleverelephant.ca
Thu Nov 30 13:41:38 PST 2017
Author: pramsey
Date: 2017-11-30 13:41:38 -0800 (Thu, 30 Nov 2017)
New Revision: 16132
branches/2.3/NEWS
branches/2.3/liblwgeom/cunit/cu_out_encoded_polyline.c
branches/2.3/liblwgeom/lwout_encoded_polyline.c
branches/2.3/postgis/lwgeom_export.c
Modified: branches/2.3/NEWS
--- branches/2.3/NEWS 2017-11-30 21:41:27 UTC (rev 16131)
+++ branches/2.3/NEWS 2017-11-30 21:41:38 UTC (rev 16132)
@@ -3,7 +3,7 @@
* Bug Fixes and Enhancements
+ - #3713, Support encodings that happen to output a '\' character
PostGIS 2.3.5
Modified: branches/2.3/liblwgeom/cunit/cu_out_encoded_polyline.c
--- branches/2.3/liblwgeom/cunit/cu_out_encoded_polyline.c 2017-11-30 21:41:27 UTC (rev 16131)
+++ branches/2.3/liblwgeom/cunit/cu_out_encoded_polyline.c 2017-11-30 21:41:38 UTC (rev 16132)
@@ -39,6 +39,13 @@
static void out_encoded_polyline_test_geoms(void)
+ /* Magic Linestring */
+ do_encoded_polyline_test(
+ "SRID=4326;LINESTRING(33.6729 38.7071,33.6692 38.701,33.6673 38.6972,33.6626 38.6871)",
+ 5,
+ "k~fkFsvolEbe at bVvVzJb~@j\\");
+ return;
/* Linestring */
"LINESTRING(-120.2 38.5,-120.95 40.7,-126.453 43.252)",
Modified: branches/2.3/liblwgeom/lwout_encoded_polyline.c
--- branches/2.3/liblwgeom/lwout_encoded_polyline.c 2017-11-30 21:41:27 UTC (rev 16131)
+++ branches/2.3/liblwgeom/lwout_encoded_polyline.c 2017-11-30 21:41:38 UTC (rev 16132)
@@ -108,8 +108,6 @@
each value with 0x20 if another bit chunk follows and add 63*/
int nextValue = (0x20 | (numberToEncode & 0x1f)) + 63;
stringbuffer_aprintf(sb, "%c", (char)nextValue);
- if(92 == nextValue)
- stringbuffer_aprintf(sb, "%c", (char)nextValue);
/* Break the binary value out into 5-bit chunks */
numberToEncode >>= 5;
@@ -117,8 +115,6 @@
numberToEncode += 63;
stringbuffer_aprintf(sb, "%c", (char)numberToEncode);
- if(92 == numberToEncode)
- stringbuffer_aprintf(sb, "%c", (char)numberToEncode);
lwfree(delta);
Modified: branches/2.3/postgis/lwgeom_export.c
--- branches/2.3/postgis/lwgeom_export.c 2017-11-30 21:41:27 UTC (rev 16131)
+++ branches/2.3/postgis/lwgeom_export.c 2017-11-30 21:41:38 UTC (rev 16132)
@@ -635,7 +635,6 @@
PG_RETURN_NULL();
lwgeom = lwgeom_from_gserialized(geom);
- PG_FREE_IF_COPY(geom, 0);
if (PG_NARGS() > 1 && !PG_ARGISNULL(1))
@@ -645,8 +644,9 @@
encodedpolyline = lwgeom_to_encoded_polyline(lwgeom, precision);
lwgeom_free(lwgeom);
+ PG_FREE_IF_COPY(geom, 0);
- result = cstring2text(encodedpolyline);
+ result = cstring2text(encodedpolyline);
lwfree(encodedpolyline);
PG_RETURN_TEXT_P(result);
