[postgis-tickets] r15869 - There's no reason why postgis_noop should be volatile
Sandro Santilli
strk at kbt.io
Mon Oct 2 04:49:32 PDT 2017
Author: strk
Date: 2017-10-02 04:49:32 -0700 (Mon, 02 Oct 2017)
New Revision: 15869
trunk/postgis/postgis.sql.in
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in 2017-10-02 06:21:52 UTC (rev 15868)
+++ trunk/postgis/postgis.sql.in 2017-10-02 11:49:32 UTC (rev 15869)
@@ -1502,7 +1502,7 @@
CREATE OR REPLACE FUNCTION postgis_noop(geometry)
RETURNS geometry
AS 'MODULE_PATHNAME', 'LWGEOM_noop'
- LANGUAGE 'c' VOLATILE STRICT _PARALLEL
+ LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL
COST 10;
-- Availability: 2.3.0
