[postgis-tickets] [PostGIS] #3845: ST_LocateAlong returns error on poorly measured LRS data
    trac at osgeo.org
    Mon Oct  2 05:39:38 PDT 2017
  Reporter:  pauldzy      |      Owner:  pramsey
      Type:  enhancement  |     Status:  new
  Priority:  low          |  Milestone:  PostGIS 2.3.4
 Component:  postgis      |    Version:  2.3.x
Resolution:               |   Keywords:  ST_LocateAlong LRS
Description changed by pramsey:
Old description:
> I have an LRS geometry from the USGS NHD dataset whereby the final two
> points of the line have the same measure values for unknown reasons.
> This is incorrect of course but not overly invalid.  When running
> ST_LocateAlong against that final measure I get
>    ERROR: Zero measure-length line encountered!
>    SQL state: XX000
> Ideally I would prefer a more forgiving logic, perhaps return NULL if we
> consider this line truly invalid or perhaps just look past the duplicate
> measure to return results.  I suppose this could be tied as well to the
> lack of an LRS geometry validator in PostGIS.
> Thanks,
> Paul
> SELECT
> ST_LocateAlong(
>     ST_GeomFromEWKT('SRID=5070;LINESTRINGM(460845.826402341
> 773926.724512888 46.31061,460836.315093686 773887.969539204
> 45.72465,460815.740949801 773767.245317281 43.92644,460817.438766447
> 773729.386836077 43.37001,460817.438778068 773729.386605209 43.37001)')
>    ,43.37001
New description:
    SQL state: XX000
 Thanks,
 Paul
 SELECT
 ST_LocateAlong(
    ,43.37001
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3845#comment:1>
