[postgis-tickets] r15871 - Gracefully handle short-measure issue (Closes #3845)
Paul Ramsey
pramsey at cleverelephant.ca
Mon Oct 2 05:50:57 PDT 2017
Author: pramsey
Date: 2017-10-02 05:50:57 -0700 (Mon, 02 Oct 2017)
New Revision: 15871
branches/2.3/NEWS
branches/2.3/liblwgeom/lwlinearreferencing.c
Modified: branches/2.3/NEWS
--- branches/2.3/NEWS 2017-10-02 11:51:01 UTC (rev 15870)
+++ branches/2.3/NEWS 2017-10-02 12:50:57 UTC (rev 15871)
@@ -24,6 +24,7 @@
- #3818, Triangles unclosed in M should be parseable
- #3866, Rare crash generating TWKB with large coordinate values
- #3869, Fix build with "gold" linker
+ - #3845, Gracefully handle short-measure issue
PostGIS 2.3.3
Modified: branches/2.3/liblwgeom/lwlinearreferencing.c
--- branches/2.3/liblwgeom/lwlinearreferencing.c 2017-10-02 11:51:01 UTC (rev 15870)
+++ branches/2.3/liblwgeom/lwlinearreferencing.c 2017-10-02 12:50:57 UTC (rev 15871)
@@ -50,14 +50,15 @@
*pn = *p1;
return LW_TRUE;
- /* If the points are different we can out.
- Correct behavior is probably an mprop of 0.5? */
- lwerror("Zero measure-length line encountered!");
- return LW_FALSE;
+ /* If the points are different we split the difference */
+ mprop = 0.5;
+ else
+ mprop = (m - m1) / (m2 - m1);
/* M is in range, new point to be generated. */
- mprop = (m - m1) / (m2 - m1);
pn->x = p1->x + (p2->x - p1->x) * mprop;
pn->y = p1->y + (p2->y - p1->y) * mprop;
pn->z = p1->z + (p2->z - p1->z) * mprop;
