[postgis-tickets] r15880 - ST_AsMVT / ST_AsMVTGeom refactor to avoid deep clone
bjorn at wololo.org bjorn at wololo.org
Tue Oct 3 11:39:41 PDT 2017
Author: bjornharrtell
Date: 2017-10-03 11:39:41 -0700 (Tue, 03 Oct 2017)
New Revision: 15880
   trunk/postgis/lwgeom_out_mvt.c
   trunk/postgis/mvt.c
   trunk/postgis/mvt.h
Modified: trunk/postgis/lwgeom_out_mvt.c
--- trunk/postgis/lwgeom_out_mvt.c	2017-10-03 10:14:10 UTC (rev 15879)
+++ trunk/postgis/lwgeom_out_mvt.c	2017-10-03 18:39:41 UTC (rev 15880)
@@ -52,7 +52,7 @@
 	bool clip_geom;
 	if (PG_ARGISNULL(0))
 		PG_RETURN_NULL();
-	geom_in = PG_GETARG_GSERIALIZED_P(0);
+	geom_in = PG_GETARG_GSERIALIZED_P_COPY(0);
 	lwgeom_in = lwgeom_from_gserialized(geom_in);
 	if (PG_ARGISNULL(1))
 		elog(ERROR, "ST_AsMVTGeom: parameter bounds cannot be null");
Modified: trunk/postgis/mvt.c
--- trunk/postgis/mvt.c	2017-10-03 10:14:10 UTC (rev 15879)
+++ trunk/postgis/mvt.c	2017-10-03 18:39:41 UTC (rev 15880)
@@ -658,12 +658,11 @@
  * Makes best effort to keep validity. Might collapse geometry into lower
  * dimension.
-LWGEOM *mvt_geom(const LWGEOM *lwgeom, const GBOX *gbox, uint32_t extent, uint32_t buffer,
+LWGEOM *mvt_geom(LWGEOM *lwgeom, const GBOX *gbox, uint32_t extent, uint32_t buffer,
 	bool clip_geom)
 	AFFINE affine;
 	gridspec grid;
-	LWGEOM *lwgeom_out = NULL;
 	double width = gbox->xmax - gbox->xmin;
 	double height = gbox->ymax - gbox->ymin;
 	double resx = width / extent;
@@ -672,14 +671,14 @@
 	double fy = -(extent / height);
 	double buffer_map_xunits = resx * buffer;
 	double buffer_map_yunits = resy * buffer;
-	const GBOX *ggbox;
+	const GBOX *lwgeom_gbox;
 	POSTGIS_DEBUG(2, "mvt_geom called");
 	/* Short circuit out on EMPTY */
 	if (lwgeom_is_empty(lwgeom))
 		return NULL;
-	ggbox = lwgeom_get_bbox(lwgeom);
+	lwgeom_gbox = lwgeom_get_bbox(lwgeom);
 	if (width == 0 || height == 0)
 		elog(ERROR, "mvt_geom: bounds width or height cannot be 0");
@@ -689,32 +688,28 @@
 	if (clip_geom) {
 		GBOX *bgbox = gbox_copy(gbox);
 		gbox_expand(bgbox, buffer_map_xunits);
-		if (!gbox_overlaps_2d(ggbox, bgbox)) {
+		if (!gbox_overlaps_2d(lwgeom_gbox, bgbox)) {
 			POSTGIS_DEBUG(3, "mvt_geom: geometry outside clip box");
 			return NULL;
-		if (!gbox_contains_2d(bgbox, ggbox)) {
+		if (!gbox_contains_2d(bgbox, lwgeom_gbox)) {
 			double x0 = bgbox->xmin;
 			double y0 = bgbox->ymin;
 			double x1 = bgbox->xmax;
 			double y1 = bgbox->ymax;
 #if POSTGIS_GEOS_VERSION < 35
 			LWPOLY *lwenv = lwpoly_construct_envelope(0, x0, y0, x1, y1);
-			lwgeom_out = lwgeom_intersection(lwgeom, lwpoly_as_lwgeom(lwenv));
+			lwgeom = lwgeom_intersection(lwgeom, lwpoly_as_lwgeom(lwenv));
 			lwpoly_free(lwenv);
 #else
-			lwgeom_out = lwgeom_clip_by_rect(lwgeom, x0, y0, x1, y1);
+			lwgeom = lwgeom_clip_by_rect(lwgeom, x0, y0, x1, y1);
 #endif
 			POSTGIS_DEBUG(3, "mvt_geom: no geometry after clip");
-			if (lwgeom_out == NULL || lwgeom_is_empty(lwgeom_out))
+			if (lwgeom == NULL || lwgeom_is_empty(lwgeom))
 				return NULL;
-	/* if no clip output deep clone original to avoid mutation */
-	if (lwgeom_out == NULL)
-		lwgeom_out = lwgeom_clone_deep(lwgeom);
 	/* transform to tile coordinate space */
 	memset(&affine, 0, sizeof(affine));
 	affine.afac = fx;
@@ -722,7 +717,7 @@
 	affine.ifac = 1;
 	affine.xoff = -gbox->xmin * fx;
 	affine.yoff = -gbox->ymax * fy;
-	lwgeom_affine(lwgeom_out, &affine);
+	lwgeom_affine(lwgeom, &affine);
 	/* snap to integer precision, removing duplicate points */
 	memset(&grid, 0, sizeof(gridspec));
@@ -730,36 +725,34 @@
 	grid.ipy = 0;
 	grid.xsize = 1;
 	grid.ysize = 1;
-	lwgeom_out = lwgeom_grid(lwgeom_out, &grid);
+	lwgeom = lwgeom_grid(lwgeom, &grid);
 		return NULL;
 	/* if polygon(s) make valid and force clockwise as per MVT spec */
-	if (lwgeom_out->type == POLYGONTYPE ||
-		lwgeom_out->type == MULTIPOLYGONTYPE) {
-		lwgeom_out = lwgeom_make_valid(lwgeom_out);
-		lwgeom_force_clockwise(lwgeom_out);
+	if (lwgeom->type == POLYGONTYPE || lwgeom->type == MULTIPOLYGONTYPE) {
+		lwgeom = lwgeom_make_valid(lwgeom);
+		lwgeom_force_clockwise(lwgeom);
 	/* if geometry collection extract highest dimensional geometry type */
-	if (lwgeom_out->type == COLLECTIONTYPE) {
-		LWCOLLECTION *lwcoll = lwgeom_as_lwcollection(lwgeom_out);
-		lwgeom_out = lwcollection_as_lwgeom(
+	if (lwgeom->type == COLLECTIONTYPE) {
+		LWCOLLECTION *lwcoll = lwgeom_as_lwcollection(lwgeom);
+		lwgeom = lwcollection_as_lwgeom(
 			lwcollection_extract(lwcoll, max_type(lwcoll)));
-		lwgeom_out = lwgeom_homogenize(lwgeom_out);
+		lwgeom = lwgeom_homogenize(lwgeom);
 		return NULL;
-	return lwgeom_out;
+	return lwgeom;
Modified: trunk/postgis/mvt.h
--- trunk/postgis/mvt.h	2017-10-03 10:14:10 UTC (rev 15879)
+++ trunk/postgis/mvt.h	2017-10-03 18:39:41 UTC (rev 15880)
@@ -67,7 +67,7 @@
 	uint32_t c;
-LWGEOM *mvt_geom(const LWGEOM *geom, const GBOX *bounds, uint32_t extent, uint32_t buffer,
+LWGEOM *mvt_geom(LWGEOM *geom, const GBOX *bounds, uint32_t extent, uint32_t buffer,
 	bool clip_geom);
 void mvt_agg_init_context(struct mvt_agg_context *ctx);
 void mvt_agg_transfn(struct mvt_agg_context *ctx);
