[postgis-tickets] [PostGIS] #3864: Sorting by geometry is slower than sorting by geohash
trac at osgeo.org
Tue Oct 3 22:58:55 PDT 2017
Reporter: komzpa | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.1
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Comment (by komzpa):
I cannot confirm that polygon data sort is faster, too, although the
difference is 7%, not 20 as in point case:
[local] gis at gis=# create table juno_osm_polygon_pt1 as (select * from
juno_osm_polygon_unclustered order by
ST_GeoHash(ST_Transform(ST_Envelope(way),4326),10) COLLATE "C");
SELECT 9936051
Time: 211660,739 ms (03:31,661)
[local] gis at gis=# create table juno_osm_polygon_pt2 as (select * from
juno_osm_polygon_unclustered order by way);
SELECT 9936051
Time: 226570,568 ms (03:46,571)
[local] gis at gis=# create table juno_osm_polygon_pt3 as (select * from
juno_osm_polygon_unclustered order by way::bytea);
SELECT 9936051
Time: 187295,132 ms (03:07,295)
This SELECT form is used in osm2pgsql workflow.
I've tried to have a look at what can be done for points in
https://github.com/postgis/postgis/pull/146
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3864#comment:20>
