[postgis-tickets] [PostGIS] #3317: ST_LineMerge documentation should mention no support for M values
trac at osgeo.org
Wed Oct 4 00:08:47 PDT 2017
Reporter: pauldzy | Owner: robe
Type: enhancement | Status: new
Priority: low | Milestone: PostGIS 2.2.6
Component: documentation | Version: 2.1.x
Resolution: | Keywords: ST_LineMerge
Comment (by robe):
strk you have that GEOS ticket closed was it ever committed or was it
committed into some test branch
output is still same as of:
POSTGIS="2.4.0 r15853" PGSQL="100" GEOS="3.7.0dev-CAPI-1.11.0 8fe2ce6"
PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 2.2.2, released 2017/09/15"
LIBXML="2.7.8" LIBJSON="0.12" LIBPROTOBUF="1.2.1" RASTER
SELECT ST_AsEWKT(
ST_LineMerge(
ST_GeomFromEWKT('SRID=0;MULTILINESTRINGM((-29 -27 10,-30 -29.7
20,-36 -31 30,-45 -33 40),(-45 -33 40,-46 -32 50))')
st_asewkt
LINESTRING(-29 -27,-30 -29.7,-36 -31,-45 -33,-46 -32)
(1 row)
Do we need to change something in PostGIS to enable M output o
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3317#comment:3>
