[postgis-tickets] r15883 - update news to reflect PostGIS 2.4.0 has been released and start a new section for PostGIS 2.5.0
Regina Obe
lr at pcorp.us
Wed Oct 4 09:17:03 PDT 2017
Author: robe
Date: 2017-10-04 09:17:03 -0700 (Wed, 04 Oct 2017)
New Revision: 15883
trunk/NEWS
trunk/doc/release_notes.xml
Modified: trunk/NEWS
--- trunk/NEWS 2017-10-04 15:52:17 UTC (rev 15882)
+++ trunk/NEWS 2017-10-04 16:17:03 UTC (rev 15883)
@@ -1,33 +1,10 @@
-PostGIS 2.4.0rc2
-2017/09/24
-* Fixes and Enhancements since PostGIS 2.4.0rc1 *
- - Numerous fixes to ST_AsMVT, ST_AsGeoBuf
- - ST_AsTWKB speed and memory performance enhancments
- - ST_RepeatedPoints speed improvements
- - ST_ConcaveHull bug fix
+PostGIS 2.5.0
+2018/xx/xx
+* New Features *
-See PostGIS 2.4.0 section for details of
-new features and enhancements in this release.
-PostGIS 2.4.0rc1
-2017/09/13
-Note possible breaking changes since 2.4.0 beta1 release are:
-* Breaking Changes *
- - B-Tree index operators < = > changed to provide better spatial locality on sorting
- and have expected behavior on GROUP BY.
- If you have btree index for geometry or geography, you need to REINDEX it, or review
- if it was created by accident and needs to be replaced with GiST index.
- If your code relies on old left-to-right box compare ordering,
- update it to use << >> operators.
- - ST_AsMVT aggregate now overloaded and arg order changed.
- Check your code if you are already using this function.
- - _ST_DumpPoints removed, was no longer needed after PostGIS 2.1.0
- when ST_DumpPoints got reimplemented in C
-See PostGIS 2.4.0 section for details of new features and fixes in this release
PostGIS 2.4.0
-2017/09/xx
+2017/09/30
* New Features *
- #3822, Have postgis_full_version() also show and check version of
@@ -75,24 +52,34 @@
- #3844, Make = operator a strict equality test, and < > to rough "spatial sorting"
- #3855, ST_AsTWKB memory and speed improvements
+PostGIS 2.4.0rc2
+2017/09/24
+* Fixes and Enhancements since PostGIS 2.4.0rc1 *
+ - Numerous fixes to ST_AsMVT, ST_AsGeoBuf
+ - ST_AsTWKB speed and memory performance enhancments
+ - ST_RepeatedPoints speed improvements
+ - ST_ConcaveHull bug fix
+See PostGIS 2.4.0 section for details of
+new features and enhancements in this release.
+PostGIS 2.4.0rc1
+2017/09/13
+Note possible breaking changes since 2.4.0 beta1 release are:
- - Dropped support for PostgreSQL 9.2.
- - #3810, GEOS 3.4.0 or above minimum required to compile
- - Most aggregates now marked as parallel safe,
- which means most aggs have to be dropped / recreated.
- If you have views that utilize PostGIS aggs,
- you'll need to drop before upgrade and recreate after upgrade
- - #3578, ST_NumInteriorRings(POLYGON EMPTY) now returns 0 instead of NULL
+ update it to use << >> operators.
+ - ST_AsMVT aggregate now overloaded and arg order changed.
+ Check your code if you are already using this function.
+ - _ST_DumpPoints removed, was no longer needed after PostGIS 2.1.0
+ when ST_DumpPoints got reimplemented in C
+See PostGIS 2.4.0 section for details of new features and fixes in this release
PostGIS 2.4.0beta1
2017/09/02
Modified: trunk/doc/release_notes.xml
--- trunk/doc/release_notes.xml 2017-10-04 15:52:17 UTC (rev 15882)
+++ trunk/doc/release_notes.xml 2017-10-04 16:17:03 UTC (rev 15883)
@@ -3,9 +3,10 @@
<title>Appendix</title>
<subtitle>Release Notes</subtitle>
<sect1>
<title>Release 2.4.0</title>
- <para>Release date: 2017/09/xx</para>
+ <para>Release date: 2017/09/30</para>
<simplesect><title>New Features</title>
<para>#3822, Have postgis_full_version() also show and check version of
PostgreSQL the scripts were built against (Sandro Santilli)</para>
@@ -72,6 +73,7 @@
update it to use << >> operators.</para>
</simplesect>
</sect1>
<sect1>
<title>Release 2.3.3</title>
<para>Release date: 2017/07/01</para>
