[postgis-tickets] r15885 - Get rid of trailing spaces
Regina Obe lr at pcorp.us
Wed Oct 4 09:57:32 PDT 2017
Author: robe
Date: 2017-10-04 09:57:31 -0700 (Wed, 04 Oct 2017)
New Revision: 15885
   trunk/postgis/lwgeom_functions_basic.c
Modified: trunk/postgis/lwgeom_functions_basic.c
--- trunk/postgis/lwgeom_functions_basic.c	2017-10-04 16:19:29 UTC (rev 15884)
+++ trunk/postgis/lwgeom_functions_basic.c	2017-10-04 16:57:31 UTC (rev 15885)
@@ -102,7 +102,7 @@
 Datum LWGEOM_asEWKT(PG_FUNCTION_ARGS);
 Datum LWGEOM_hasBBOX(PG_FUNCTION_ARGS);
 Datum LWGEOM_azimuth(PG_FUNCTION_ARGS);
-Datum LWGEOM_angle(PG_FUNCTION_ARGS);
+Datum LWGEOM_angle(PG_FUNCTION_ARGS);
 Datum LWGEOM_affine(PG_FUNCTION_ARGS);
 Datum LWGEOM_longitude_shift(PG_FUNCTION_ARGS);
 Datum optimistic_overlap(PG_FUNCTION_ARGS);
@@ -2434,19 +2434,19 @@
 	GSERIALIZED * seri_geoms[4];
 	LWGEOM *geom_unser;
 	LWPOINT *lwpoint;
-	POINT2D points[4];
+	POINT2D points[4];
 	double az1,az2 ;
 	double result;
 	int srids[4];
-	int i = 0 ;
+	int i = 0 ;
 	int j = 0;
-	int err_code = 0;
-	int n_args = PG_NARGS();
+	int err_code = 0;
+	int n_args = PG_NARGS();
 	/* no deserialize, checking for common error first*/
 	for(i=0; i<n_args; i++)
-		seri_geoms[i] = PG_GETARG_GSERIALIZED_P(i);
+		seri_geoms[i] = PG_GETARG_GSERIALIZED_P(i);
 		if (gserialized_is_empty(seri_geoms[i]) )
 		{/* empty geom */
 			if (i==3)
@@ -2467,7 +2467,7 @@
 			else
-				srids[i] = gserialized_get_srid(seri_geoms[i]) ;
+				srids[i] = gserialized_get_srid(seri_geoms[i]) ;
 				if(srids[0] != srids[i])
 				{/* error on srid*/
 					err_code = 3 ;
@@ -2481,17 +2481,17 @@
 			default: /*always executed*/
 			for (j=0;j<=i;j++)
 				PG_FREE_IF_COPY(seri_geoms[j], j);
 			case 1:
-			lwpgerror("Empty geometry");
+			lwpgerror("Empty geometry");
 			PG_RETURN_NULL() ;
 			break;
 			case 2:
 			lwpgerror("Argument must be POINT geometries");
 			PG_RETURN_NULL();
 			break;
 			case 3:
 			lwpgerror("Operation on mixed SRID geometries");
 			PG_RETURN_NULL();
@@ -2499,19 +2499,19 @@
 	/* extract points */
-		geom_unser = lwgeom_from_gserialized(seri_geoms[i]) ;
-		lwpoint = lwgeom_as_lwpoint(geom_unser);
+		geom_unser = lwgeom_from_gserialized(seri_geoms[i]) ;
+		lwpoint = lwgeom_as_lwpoint(geom_unser);
 		if (!lwpoint)
 			for (j=0;j<n_args;j++)
-			lwpgerror("Error unserializing geometry");
+			lwpgerror("Error unserializing geometry");
 			PG_RETURN_NULL() ;
 		if ( ! getPoint2d_p(lwpoint->point, 0, &points[i]) )
 			/* // can't free serialized geom, it might be needed by lw
 				PG_FREE_IF_COPY(seri_geoms[j], j); */
@@ -2519,26 +2519,26 @@
 			PG_RETURN_NULL();
 		/* lwfree(geom_unser);don't do, lw may rely on this memory
-		lwpoint_free(lwpoint); dont do , this memory is needed ! */
+		lwpoint_free(lwpoint); dont do , this memory is needed ! */
 	/* compute azimuth for the 2 pairs of points
-	 * note that angle is not defined identically for 3 points or 4 points*/
+	 * note that angle is not defined identically for 3 points or 4 points*/
 	if (n_args == 3)
 	{/* we rely on azimuth to complain if points are identical */
 		if ( ! azimuth_pt_pt(&points[0], &points[1], &az1) )
-			PG_RETURN_NULL();
+			PG_RETURN_NULL();
 		if ( ! azimuth_pt_pt(&points[2], &points[1], &az2) )
-			PG_RETURN_NULL();
+			PG_RETURN_NULL();
 	} else
 			PG_RETURN_NULL();
 		if ( ! azimuth_pt_pt(&points[2], &points[3], &az2) )
-			PG_RETURN_NULL();
+			PG_RETURN_NULL();
 	result = az2-az1 ;
 	result += (result<0) * 2 * M_PI ; /* we dont want negative angle*/
