[postgis-tickets] r15895 - Remove duplicated DATA and useless EXTRA_CLEAN append
Sandro Santilli
strk at kbt.io
Thu Oct 5 04:33:02 PDT 2017
Author: strk
Date: 2017-10-05 04:33:02 -0700 (Thu, 05 Oct 2017)
New Revision: 15895
trunk/extensions/postgis/Makefile.in
Modified: trunk/extensions/postgis/Makefile.in
--- trunk/extensions/postgis/Makefile.in 2017-10-05 11:28:42 UTC (rev 15894)
+++ trunk/extensions/postgis/Makefile.in 2017-10-05 11:33:02 UTC (rev 15895)
@@ -22,7 +22,7 @@
$(GREP) "[a-zA-Z]" | \
$(PERL) -pe 's/(\d+[a-zA-Z]+)\d*/\1/'
-DATA = $(filter-out $(wildcard sql/*--*.sql),$(wildcard sql/*.sql))
+DATA = $(wildcard sql/*--*.sql)
#DOCS = $(wildcard ../../doc/html/*.html)
PG_CONFIG = @PG_CONFIG@
@@ -100,9 +100,6 @@
ln -fs $(EXTENSION)--ANY-$(EXTVERSION).sql sql/$(EXTENSION)--$$OLD_VERSION--$(EXTVERSION).sql; \
done
-DATA = $(wildcard sql/*--*.sql)
-EXTRA_CLEAN += sql/$(EXTENSION)--$(EXTVERSION).sql sql/postgis--unpackaged--$(EXTVERSION).sql
distclean: clean
rm -f Makefile
