[postgis-tickets] r15907 - Suite name should match file name
Paul Ramsey
pramsey at cleverelephant.ca
Thu Oct 5 11:21:41 PDT 2017
Author: pramsey
Date: 2017-10-05 11:21:41 -0700 (Thu, 05 Oct 2017)
New Revision: 15907
trunk/liblwgeom/cunit/cu_algorithm.c
Modified: trunk/liblwgeom/cunit/cu_algorithm.c
--- trunk/liblwgeom/cunit/cu_algorithm.c 2017-10-05 14:37:07 UTC (rev 15906)
+++ trunk/liblwgeom/cunit/cu_algorithm.c 2017-10-05 18:21:41 UTC (rev 15907)
@@ -1189,7 +1189,7 @@
void algorithms_suite_setup(void);
- CU_pSuite suite = CU_add_suite("computational_geometry", init_cg_suite, clean_cg_suite);
+ CU_pSuite suite = CU_add_suite("algorithm", init_cg_suite, clean_cg_suite);
PG_ADD_TEST(suite,test_lw_segment_side);
PG_ADD_TEST(suite,test_lw_segment_intersects);
PG_ADD_TEST(suite,test_lwline_crossing_short_lines);
