[postgis-tickets] r15909 - Make lwgeom_dimensionality use a const argument
Paul Ramsey
pramsey at cleverelephant.ca
Thu Oct 5 12:36:45 PDT 2017
Author: pramsey
Date: 2017-10-05 12:36:45 -0700 (Thu, 05 Oct 2017)
New Revision: 15909
trunk/liblwgeom/liblwgeom.h.in
trunk/liblwgeom/lwgeom.c
Modified: trunk/liblwgeom/liblwgeom.h.in
--- trunk/liblwgeom/liblwgeom.h.in 2017-10-05 19:34:16 UTC (rev 15908)
+++ trunk/liblwgeom/liblwgeom.h.in 2017-10-05 19:36:45 UTC (rev 15909)
@@ -1305,7 +1305,7 @@
* Return the dimensionality (relating to point/line/poly) of an lwgeom
-extern int lwgeom_dimensionality(LWGEOM *geom);
+extern int lwgeom_dimensionality(const LWGEOM *geom);
/* Is lwgeom1 geometrically equal to lwgeom2 ? */
extern char lwgeom_same(const LWGEOM *lwgeom1, const LWGEOM *lwgeom2);
Modified: trunk/liblwgeom/lwgeom.c
--- trunk/liblwgeom/lwgeom.c 2017-10-05 19:34:16 UTC (rev 15908)
+++ trunk/liblwgeom/lwgeom.c 2017-10-05 19:36:45 UTC (rev 15909)
@@ -1426,7 +1426,7 @@
-static int lwcollection_dimensionality(LWCOLLECTION *col)
+static int lwcollection_dimensionality(const LWCOLLECTION *col)
int i;
int dimensionality = 0;
@@ -1439,7 +1439,7 @@
return dimensionality;
int dim;
@@ -1474,7 +1474,7 @@
break;
case COLLECTIONTYPE:
- return lwcollection_dimensionality((LWCOLLECTION *)geom);
+ return lwcollection_dimensionality((const LWCOLLECTION *)geom);
break;
default:
lwerror("lwgeom_dimensionality: unsupported input geometry type: %s",
