[postgis-tickets] r15911 - Remove un-used function flip_coordinates
Sandro Santilli
strk at kbt.io
Thu Oct 5 13:17:37 PDT 2017
On Thu, Oct 05, 2017 at 12:59:39PM -0700, Paul Ramsey wrote:
> Author: pramsey
> Date: 2017-10-05 12:59:39 -0700 (Thu, 05 Oct 2017)
> New Revision: 15911
> Modified:
> trunk/liblwgeom/cunit/cu_libgeom.c
> trunk/liblwgeom/liblwgeom.h.in
> trunk/liblwgeom/lwgeom.c
> Log:
> -extern LWGEOM* lwgeom_remove_repeated_points(const LWGEOM *in, double tolerance);
> +extern void lwgeom_remove_repeated_points_in_place(LWGEOM *in, double tolerance);
I thought the plan was to avoid returning void ? What if the input
geometry is invalid for any reason ?
PS: please list all changes in the commit log.
--strk;
